Question about Hyundai 3500W 6.5HP Portable Generator
Spark plug for hyundai 3500 generator - Hyundai 3500W 6.5HP Portable Generator
Anyone know the part number or a cross ref number for the spark plug in a nikota 3500 w 6.5 hp generator
$14.95 for this one. If you take the plug out of it, the reference number will be on it. Put the number into Google and you will get the equivalents in other makes.
NGK Spark Plug Motor Parts For Niko Nikota 6 5HP 3500 Watts Generators
Dec 10, 2017 | Electrical Supplies
Take the plug to any small engine shop and they should be able to get you one that's compatible.
Dec 10, 2017 | HP Electrical Supplies
Sonata spark plugs
here you go
Hyundai Sonata Spark Plug - AutoZone
www.autozone.com/external-engine/spark-plug/hyundai/sonata
  1. Cached
On modified performance engines, it's generally best to use a colder heat range plug. Old spark plugs for Hyundai Sonata often produce a rough and jittery ...
Hyundai Sonata Spark Plugs - Spark Plug - Denso NGK Bosch - 2011 ...
www.partsgeek.com > Spark Plugs > Hyundai Spark Plugs > Sonata Parts
  1. Cached
  2. Similar
Rating: 5 - ‎25 reviews Spark Plugs produce the spark for fuel combustion in your vehicle's engine.
How to Change Spark Plugs on Hyundai Sonata - 4 cylinder - YouTube
2q==? 5:08 https://www.youtube.com/watch?v=Dr8HOJv7HzM
  1. Similar
Apr 13, 2014 - Uploaded by HappenToLife This is a how to video for changing spark plugs on a Hyundai Sonata. The car in the video is a 2007 model ...
Hyundai Sonata Spark Plug - Auto Parts Warehouse
www.autopartswarehouse.com > Hyundai > Sonata > Spark Plug
  1. Cached
  2. Similar
BOSCH PLATINUM+4 SPARK PLUGS. Engineered with advanced surface air gap set-up for prolonged, more powerful spark; Features platinum center ... sonata spark plugs Google Search
Apr 14, 2017 | Cars & Trucks
The generator wont start. it is a steele 3500 watt generator
Serenity,
First I think you should start by looking at the ignition system.
To find the fault please follow these steps:
  1. Removed the spark plug from the engine and re-attach to the Ignition HT Lead. Hold the end of the spark plug tip to a metal section of the engine, and turn over the engine (you might need a friend to help if your generator does not have electric start). If all is working correctly, you should see a strong spark, and the engine should run smoothly.
  2. If you do not get a spark, you next need to check oil level is at correctly level (to the very top as if about to flow out) and repeat step 1.
  3. If you still have no spark or it stops running within a few minutes of starting, disconnect the oil sensor wire (you will find it on the front coming from your engine just to the top left of the oil filler cap) and try step 1 again.
  4. Still not getting a spark? Then you need to replace your ignition coil. You can order one from us from our website on this page: http://www.generatorguru.com/sp-gg350/?sort=featured
If you are getting a spark, but still having trouble starting the Generator, there is most likely a fuel problem too. We can assist you with the next set of fault-finding tests if you need some help. Let us know how it goes. :)
http://www.generatorguru.com/ask-the-guru/
Dec 11, 2016 | Electrical Supplies
Greetings: I have a 3500 wts 6.5 Nikota generator, turn on and off several seconds. The carburetor is fine, ignition, too. The shoot off well, I would like to give me an idea that can be
you saying it wont keep running
you have spark at the new spark plug
fuel is fresh and uncontaminated
could be
the coil or the plug lead
ok when cool ... fails when hot
the Governor setting
carby jet blockage
if a four stroke a valve adjustment might help
Oct 12, 2016 | Electrical Supplies
I have a briggs and stratton 030547 3500 Watt generator and the engine has locked up, what can i do to fix this issue??
Remove the spark plug and crank the engine . Usually it has been flooded or shut while in full choke mode. This causes the condition you describe. If that fails you have internal issues and low oil was the culprit.
Jun 05, 2014 | Briggs & Stratton Electrical Supplies
Hyundai 3500 generator carb adjustment
Go to the Hyundai website and ask for the user's manual.. They should have it as a download!
Dec 24, 2012 | Hyundai HHD3500 3500-Watt 4-Stoke Portable...
I bought a champion generator 2 yrs ago.It ran when I bought it. Have not occasion to use it until now. It will not fire. It had some rust on the flywheel. Removed the rust. I replaced the spark plug.
Probably only one of these issues to cause that. gas not turned on or flooded- ck spark plug to see if it is wet, check to see if the spark plug is getting power by taking it out leaving the wire on it and holding it about a 1/8 of a inch away from some exposed metal part of the frame and have someone try to start it. if you get a spark then ck your gap and put it back. Ck your choke too to see if it is on. also if it was flooded then leave the choke off and keep trying to start it. if it was stored outside, it may have water in the gas.
Oct 27, 2012 | Champion 3500/4000 Watt Portable Generator
2004 Tiburon...drove earlier today then parked. Tried to start it again but it would not start. I checked all of the fuses related to the ignition system and checked for spark on each of the coils.None of...
If there is none of spark at each spark plug when you crank the engine. Assuming that you checked the spark like that, unless you have other way in doing this, then the problem is the ignition module.
The spark at the secondary coil is only generates a spark at a spark plug if there is a pulse voltage at a primary coil. The pulse voltage is not there then there is no spark. The one generates the pulse voltage is the ignition module when the starting is in action. Hop this can help.
Sep 13, 2010 | 2003 Hyundai Tiburon
Hyundai 3500W 6.5HP Portable Generator Logo
75 people viewed this question
Top Hyundai Electrical Supplies Experts
john h
fred_therese
Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
