Question about Sony CMTEH15 Audio Shelf System
Goes into standby mode on closing CD Cover - Sony CMTEH15 Audio Shelf System
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
NO STANDBY MODE WHEN CLOSING LID
hmmm is the button on the computer that lid touches working ok?
might want to manually test that with finger tip to determine if it's working
May 25, 2012 | IBM 92P6569 DVD/CD-RW for ThinkPad R50,...
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Standby mode
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
How do I get to standby mode?
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Lamp
I'm still not sure about your question. Let me quess that by saying power/standy light goes to red...that mean your computer
is going into standby mode.!!!! So do it this way..on the left or right top corner of your notebook not the monitor, you should be having a small pin pointing up..I think that pin is use when you close the lid of your Laptop and it make your laptop goes into standby mode.When I mean goes into standby(sleep mode) the first think you can notice that your monitor light will be off and you can still see a very light image.So maybe this pin is stuck try to push it down for several times..
best of luck, takecare
Theknack.
Apr 19, 2008 | Computers & Internet
Sony CMTEH15 Audio Shelf System Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
