Question about Xerox Office Equipment & Supplies
Xerox workcentre 7545 powering up and wont start .? flashing what is the problem
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
  • 24 Answers
SOURCE: I have a Xerox WorkCentre 5638. How do I save
You cannot save the e-mail addresses on this unit except by creating a .CSV file and uploading it via CWIS under Properties>Services>E-Mail>Public Address Book. A link to the instructions is below:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=195,E=0000000001733361539,K=3118,Sxi=11,Case=obj(10395)
Posted on Oct 25, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
My copier won't shut down after being powered off.
They need to cool down. Try unplugging it after a few minutes of running, then turn the power of and on a couple times. Let it sit for a few minutes then turn back run it then turn it off again.
May 16, 2016 | Xerox Workcentre 7545/P 7545P Color...
WHAT IS THE NVM RESET FUSER CODE FOR THE XEROX 7545 COPIER\
Have a look at the following link:
http://www.enxmag.com/2013_months/aug2013/WorkCentre7425StyleFaultCodeList_82013.htm
It has a list of fault codes and also tells you how to reset NVM counts. Look in the bottom right of the page for the instructions. Hope this helps.
Jul 16, 2014 | Xerox Workcentre 7545/P 7545P Color...
Cleaned waste toner out but xerox 7545 wont ecept it says to replace waste tone
You didn't clean the bright plastic bubble at the upper inside end.
If dirty, machine thinks it is still full of toner.
Jun 24, 2014 | Xerox Workcentre 7545/PT 7545PT Color...
My xerox 7545 workcentre comes on, but it does not show the menu screen. it goes to fully on, but could not able to pick up menu screen.
Hello, The first thing you need to do it power down,unplug the workcentre and let sit for 2 mins. Plug back in and observe. If this doesn't work it will result in a call to your service provider and a field tech will have to trouble shoot the problem.
May 15, 2014 | Xerox WorkCentre 7545/P Copier
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
