Question about Kettler AXOS Cross P Elliptical Trainer"
Err4 axos cross p - Kettler AXOS Cross P Elliptical Trainer"
Err4 what can i do?
One of the thermocouple temperatues is more then 50 degrees. Please consult your service provider
Sep 23, 2014 | Science & Laboratory
Hello, I've just bought a Voit Eco Elliptical cross-trainer - had it set-up - and have used it once. Now it doesn't work, at the 2nd work-out! The screen indicates 'ERR4'. I've tried to reset it, stop...
Hi Belinda,
I know someone who was seeing the same error and also tried resetting the computer on the machine but did not work. As per what they told me it was some issue with the Motor. And they could replace the motor under warranty and the issue was resolved. you can try doing the same thing if nothing works. cheers.
Aug 21, 2013 | Exercise & Fitness
Kettler axos Cross p crosstrainer. First Time use. Err4 On Display, no Reaktion On keys. What can i do?
adjust the REED switch see the diagram, clean, and tigh the wires connector very well.
2) tight the ribbon cables, clean it,very well
3) tight the display board connector vs lower board connector
Try again. 4) If this not function Try to RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Aug 31, 2012 | Exercise & Fitness
Esp-6tm controller shows err3 and err4 but one and five zones work. turned valaes on manually and the water comes out of heads. bad control box ?
When you say turned on valves manually, do you mean by operating the bleeders on the individual valves? If so, that has nothing to do with the electrical operation of the valves.
The fact that you are getting err3 & err4 leads me to believe that the wiring that electrically operate these valves are shorted.
Move the wires for valves 3 & 4 to terminals 1 & 2 on the timer and see what happens.
If err1 and err2 come up, the problem is in the wiring to the valves #3 & #4.
Gary
Jul 03, 2011 | Rain Bird Hardware & Accessories
Err4 message
On a Kitchenaid coffee maker, ERR 4 indicates a stuck button. Please double check to make sure none of your buttons are sticking in place and "freezing" the coffee maker. If you can not find any obvious problems, I would recommend calling Kitchenaid Customer Service to see what options may be available to you.
Their toll-free phone number is 1-800-541-6390.
Feb 06, 2009 | KitchenAid KCM511 Coffee Maker
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Kettler AXOS Cross P Elliptical Trainer" Logo
64 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
