Question about HP Officejet 5610 All-In-One InkJet Printer
Hp all in one fax dials but keeps getting no answer.
The fax is set up with our main phone line. The printer, scan and copy part of the printer works fine. We moved our office and must not have something set up correctly. We cannot receive a fax or send one although it does dial, just gets a no answer message.
Any help would be greatly appreciated.
Thank you,
Michelle
  • 45 Answers
Hi Michelle,
Please check the following link to resolve this issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01502049&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank U
Posted on Jan 21, 2009
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
Hp c309a printer/fax/scan/copy - fax's sent not being rec'd and cannot receive incoming. Ran fax test and shows "pass" on all items.
hate to ask, but is the phone line from back of printer in the correct port, the one for 1 line, next check the connection to the wall or splitter, if you are using a splitter, radio shack type, try the other side, and last, if you have a single hand set, check to see if you have dial tone at that connection. now if you are using cable modem for your phone and fax, you will need to contact them for assistance.
Sep 22, 2010 | HP Photosmart Premium C309A All-In-One...
It will no longer scan and will not receive Fax. It will still copy and print
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components.
Which is contains the hp director software. Which shows the scanning option For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
for fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Feb 26, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Unable to send and receive fax from hp 3050 series
check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 29, 2010 | HP Color LaserJet 3500 Printer
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Connecting problems
Is it set to auto receive, is the tel line plug into socket marked line not tel. Is it used on a dedicated line, no extensions, if using ADSL you must have filter on line. If plugging standard phone in place of fax is dial tone heard and line is noise free, can you ring and speak fine on line using a phone. Is machine set to correct dial format for your country ie pulse or tone. When did it stop, have you had storms, phone work done, has it worked on this line before? I take it it copys ok is that correct.
My bet is A noisy phone line or B set to manual answer. More info equels better help, but I am short of free time now..
Feb 02, 2009 | HP LaserJet 2840 All-In-One Printer
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
109 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
