I have Maytag washer LAT3500AAE and want to know is there a way to tighten drive belt? I see how easily one can tighten the pump belt but not drive belt. Is there a way to tighten at the motor pulley?
vest6
  • 196 Answers
SOURCE: Maytag LAT9757AAE,top load washer won't spin.
Sounds like a sticky brake assy. This type of brake is very tricky and should be checked be a service technician
It's possible to do it yourself but not recommended because of the 200 lb. pressure spring. Hope the diagram will help.
Posted on Jan 13, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washer lat9206bae drum will
hi thanks for the question looks like you have a bearing problem the dru wont turn its an expensive repair for that model of maytag they were not a good model thanks for the question the appliance doc
Posted on Sep 27, 2008
  • 686 Answers
SOURCE: LA612 maytag washer. motor too
get yourself a new belt the old one is stetched and no longer good
Posted on Jan 08, 2009
SOURCE: Maytag washer has black gunk underneath on pulleys and belt
replace the transmission
Posted on May 26, 2009
mindreader
  • 578 Answers
SOURCE: The Maytag washer doesn't spin and had a burning
You should have a tensioner pully (a small wheel on a piece of spring steel) that hold the belt tight.
If that spring steel is broken or weak, then you will have to take the broken one to your local appliance repair parts shop and obtain a new one.
That should keep the belt tight and keep the drum spinning.... -Jim
Posted on Oct 23, 2009
How to tighten the belt of Maytag washer model SAV365AAWW?
Depends how good you are with disassembly. It's not that difficult and you need to shut off the water and unplug the machine. The front needs to be removed and on the bottom is where the belts are. Loosening the pump retention screws and pulling the pump towards you while you tighten at least 1 not to hold the tension. Then tighten the other screws on the pump and reverse disassembly order. Too tight on the belt will burn your pump up and of course too loose will allow them to slip. I would look and see why the belts are slipping. Water leaks, worn out? For the proper tension, on the center of the belts, you should be able to press your index finger on it and it will push in about 1/2". Good luck
Apr 18, 2017 | Maytag Washing Machines
My washer won't agitage on my maytag washer model fav6800aww. first started with a squeaking noise
Move the motor or pulley out of the way a bit and remove the old belt and replace with new, unstretched belt, tighten the motor or pulley and that is it.
Nov 14, 2015 | Maytag Washing Machines
Managemylife com
See if there is a pulley on the belt that can be moved to tighten the tension. Often the motor's mounting bolts can be loosened and the motor itself can be moved to tighten the belt and restore friction. If not possible, a new tight belt is in order.
Nov 23, 2013 | Maytag Dryers
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
Jul 22, 2013 | Maytag Atlantis MAV7551 Top Load Washer
On my washer the belt come off
You will need to use a socket set to loosen the belt tension bolt. Then place the belt over the drive wheels.
Now tighten the belt tensioning bolt, while applying force to the belt to tighten it around the drive wheels.
take care!
damnor01
Apr 28, 2012 | Maytag Washing Machines
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
Jul 01, 2011 | Magic Chef CAV2000 Top Load Washer
Maytag performa LAT3500aaae is it hard to replace
please check any locking system is provided in the cabinet and replace is it. if problem exist check for the screws of the machine must be properly screwed up
Dec 23, 2009 | Washing Machines
The washer is making loud squealing noises. I took the front panel off to take a close look and notice the motor is able to be moved back and forth. Is this normal? I tried tightening the mounts and it...
Set the drive belt over the drum, loosen the motor slightly, because I think you are cross treading the belt. check the belt before fitting to see if there is any damage to the belt. With your hand put the belt on to the drum, back onto the motor, turn very slowly until the belt finds it's own parallel (the grooves line up), then tighten the motor exactly where it is in place. If there is NO damage to the belt, set the machine onto a fast spin, empty. That should tell you it's a belt problem. But you may have to spend 10 bucks on a new belt. Cheaper than a new machine. Hope all goes go well for you, let me know! Dave
Jul 15, 2009 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
