Question about Exercise & Fitness
Roger black tread mill flashing red light on circuit board
  • Rachael Stokes Oct 19, 2013
    mines done the same any solutions?
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
SOURCE: I have an Proform 765
HAVE YOU TRIED TO CONTACT PROFORM DIRECT. SOMETIMES THEY CAN HELP OVER THE PHONE. GOOGLE THEM
Posted on Sep 26, 2010
taran_2005
  • 10515 Answers
SOURCE: I HAVE A TRIMLINE
You will need to check the speed sensor for proper alignment, cleanliness and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an a multi-meter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor.
The sensor should open and close as the magnet passes by. As long as it is doing this it is good. If the sensor is ok, I would do the following:
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slowly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 17, 2011
ercupa190
  • 12223 Answers
SOURCE: tread mill light up but
Dear Sir:
Hello I hope everything is o.k
I will help you , please try to do the following:
1)Plese turn off the power cord.
2) With a DVOM Digital Voltimeter, inspection for Continuity wires(Power Cord).
3) Reset the circuit breaker from the equipment.try again
4) Check if some wires is loose, re-solder .
5) Check with the DVOM,the primary winding for transformer, and secondary winding and see if there voltages are o.k . Smell and SEE, if some component around the transforme(power supply) like capacitor, resistor, diode, transistor are burn, or open, or shorcircuit. Replace.
6) Inspection the button of Start, check continuity , clean contact with some spray special for clean contact (Radio Shack).
7)Inspeccion the relais or contactor, if are closing and clean the contact.
8) Finally PCB faulty and Replace.
Thank you in advance, sincerely. Blessing.
If you need some additional Help, please contact me.
E. CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 27, 2011
I have a roger black fitness tread mill and my screen keep flashing when i turn it on at button what coild be problem please
Check your power supply unit. It may be simply not working properly or it is detecting a fault and shutting itself down.
Feb 10, 2017 | Exercise & Fitness
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
How to fix a treadmill
see the video attached. lube the rollers bearing front +back.
However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS.
2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty.
God bless you
Oct 19, 2013 | Exercise & Fitness
I have the Roger black treadmill and need to know the screw sizes that hold on the tread mill on the roller at top end of machine as mine come loose when running and then the belt slides of the motor..,,,,...
you need to Read the owner manual, in the section for assembly or dissasembly they appear the screw sizes needed for any section.
or download free from www.fitness.manualsonline.com +
www,retrevo.com
God bless you
Jul 17, 2013 | Exercise & Fitness
I need to know where to connect wires to the new control panel on a Nordictrack elite 7500 tread mill
please see the diagram attached and proceed according.However the black wires from motor is in A1 and Red in A2. the rest see the wiring diagram
Mar 04, 2013 | Exercise & Fitness
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
My tread mill stop working i have green light in the electonic board 5 small light not on
You need a new controller board. You can check your manual for how to order replacement parts. It will not be available on the New Balance website. It will actually be from an off-brand treadmill manufacturer that made the treadmill for New Balance.
Oct 22, 2012 | New Balance Balance 1500 Treadmill
Hi my tread mill has stopped working i could smell burning from the mortor and it was warm the seriel no is 200604 and the dc mortor model no gmd 118-1 its make is roger black can you help please
Dear Sir:
The problem can be various factors;
1) Lack of lube in deck belt( maybe is worn, and need replace)
2) The drive belt is worn, or break and need replace.
3) The main motor bearing is bad.
4) The main motor winding is burn and need repair or replace.
5) The rollers bearing is bad need replace and lube.
Take care of this, and take the step for repais in any Item
see my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
Exercise & Fitness Logo
67 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
