Question about Hotpoint Aquarius WF000 Front Load Washer
Black marks all over the rubber seal at the front of machine.
I'd like to know what might be causing black spotty marks (a bit like mold) to be all over the grey rubber seal even inside the folds. The marks won't come off with cleaning. Everything else works fine, clothes are clean, drum is clean. The machine is only a year old.
  • Hotpoint Master
  • 3,463 Answers
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Posted on Jan 21, 2009
Black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My front-loading Frigidaire washer has black mold on the rubber seal. How can I get rid of the mold? And can it be prevented?
Clean with bleach solution and a Mr Clean Magic eraser.
leave the door open to dry out the machine from now on.
Nov 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
My LG front loader washing machine has a black scum all over the rubber seal and it gets on my clothes and WILL NOT come out once it is on the clothes. I have tried bleach to get the stain off my clothes...
this is mold due to the amount of moisture built up during your wash cycle clean the scum using bleach but do not shut your door after you wash so the seal has an opportunity to dry
Aug 31, 2009 | LG WM-2277HW Front Load Washer
Black mold growing on and under rubber gasket
it should be a fairly straightforward replacement, these door seals attach to the inner tub and the front case by clamps or straps -view these to check whether its within your capability. these seals should be around the £25 mark. note the chances are these marks may start soon on the new seal !!
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Nov 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Marks on white clothes
if the machine has become more noisy of late, the the oil and greease out of the bearing has done this. Which means a heavy bill. appliance doctor
Jan 28, 2007 | LG WM-1832C Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
434 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
