Question about Maytag MAH6700AWW Neptune Front-Load Washer
The water will not run into the tub it overflows out of the detergent cups
  • 691 Answers
Pipes blocked. take the top off take the draw out and with something not too destructive clean out the pipes
Posted on Jan 10, 2013
  • Shep Oct 20, 2013
    More then likely it is caused by a sludge buildup from liquid detergent or
  • Shep Oct 20, 2013
    I hit return by accident and couldn't go back!! So to continue , a sock or small item stuck at the end of that tube between the tubs.
3 Suggested Answers
  • 198 Answers
SOURCE: water continues to run, with washer in off mode
replace inlet valve (mix valve)
Posted on Feb 28, 2009
Macmarkus
  • 2605 Answers
SOURCE: there is a plastic cup under the top of the washer
Welcome to FixYa.
I think what you're referring to is the injector assembly in those older Maytag topload washer's. Here's what I'd do.
If you take the two rubber hoses going to and from the center piece which should be almost clear plastic, you'll find a small rocket shaped injector and rubber diapragm/nozzle type component.
i.e.
Replace this and you should be fine. The injector and rubber hose typically come together ( or used to before Maytag was bought by Whirlpool ), but double check with the supplier you choose.
The part number is 400646 and usually around $10-15USD, but I haven't had to swap one out in a while so they may be more than that or come separately now.
Let me know how that works out and we can move forward from there, but that should fix the problem. Good luck.
Regards,
Macmarkus :)
Posted on Feb 26, 2011
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Our dishwasher leaves a white film on dishes
There are 3 standard answers to solving the white-deposits-on -dishes problem: 1) Use a rinse aid; 2) use less detergent; 3) use vinegar in the washer. If you have hard water, none of these may work, especially if you've had the problem for a while. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs. Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is adding so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
Mar 06, 2010 | Dishwashers
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Confusion on the need or suggestion to use HE Detergent
just a retarded recommendation they say 1 tsp of he detergent in them will do the trick .. so will anything else i have many customers do it
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Dish washer not draining
May be that there was a little regular soap or something put in that made it suds up. vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 11, 2009 | GE Dishwashers
Musty smell
This problem is caused because the water does not get totally pumped out of the outer tub and sits in the bottom of the tub and in the front seals. Eventually a mildew type scum develops and causes the washer to stink and also impart the odor to clothes. Even though front loaders do use less water and energy, all of them have essentially the same design and therefore all will eventually develop this problem.
Run a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
but with your wife's Asthma tho you could try
Typically the cause is the machine itself, but occasionally the water being used in the washer can be the source of the problem. If the smell resembles rotten eggs, you may need a water filtration system installed. After you eliminate any other possibilities, you can begin the treatment process. Create a mixture of baking soda and vinegar. Add 1/2 cup of baking soda to 2 cups of white distilled vinegar. 3Begin a wash cycle using the machine’s hottest setting. As the water rises, add the baking soda and vinegar mixture. Let the washing machine complete a full cycle. If you notice any residue that has been loosened, use a cloth to wipe the surface clean. Run a cold water cycle to complete the process. You should immediately notice that the smell has been neutralized.
Feb 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch washer smell
Just clean the filter and make sure all the water drains from the pipes, That water can be a realy smelly story, i know.
Good luck...
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Feb 10, 2007 | LG WM-2277HW Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
239 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
