Question about Sony Cyber-shot DSC-M2 Digital Camera
Buttons don't work
Sometimes when I want to take a photo, I'm trying to choose the menu options, the buttons don't work and the cam is being locked... It becomes unusable till I turn off the cam then I restart it. Can you tell me what to do please? Is there any troubleshooting method for that?
  • 89 Answers
If you can confirm the defective parts we can help you with the spares and service manuals
Posted on Jul 07, 2007
SOURCE:
Forgot lock code for wm8650
Sir/Mam
The most often method when the device hangs or just it frozen, is to remove the battery out after a couple of seconds and then putting it back again. To reset your device just dial this code *2767*3855#, this will reset your phone automatically once rebooted. But sometimes the code may not always useful specially when your Samsung Galaxy Y is frozen and become unresponsive or in other sever hang problem like it just hangs on welcome screen logo. To fix it, just then again remove the battery out, then put it back again. Don't power it ON yet, just press and hold the Volume Up, Center button and Power button at the same time. A menu will then appear that let choose with an option. Just use the volume button to toggle and select the wipe data/factory reset, that will then reset your Galaxy Y to it's factory default settings.
Thanks for using FixYa!
Oct 16, 2012 | Google Cell Phones
I need to change the menu language to English, as it turned to Chinese by mistake. Please help me. Thanks, El-sayed
Hello, That's the same camera I have! I can help you. Follow this sequence to reset all the settings so that the language becomes English:
  1. Turn cam on
  2. Press the "menu" button.
  3. Press right directional key (marked with the flash symbol)
  4. Press down directional key to go to the bottommost entry of the menu (which is the reset all option)
  5. Press the "set" key (in the middle of the directional keys)
  6. Press the up directional key and then "set" to confirm.
There. you're done. Now you don't have to learn Chinese to use your cam!
EXTRA NOTE: BTW just in case this applies to you too; When I first got my cam, I had trouble finding the timer option to time the shutter (1-2-3 click!) It's called "drive mode" in this camera.
May 07, 2011 | BenQ DC C1030 Eco Digital Camera
The card is not locked.The other message is Memory card error. I have tried two cards they both get the same message, but when I put in the one that came with the camera a 16mg card , it works fine
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car after removing and replacing the memory card and powering off then back on your cam, you may see how the system now registers your photos will having to click back and forth between AUTO and MAN. I posted very closely related troubleshooting steps to take in order to prevent your CAM from performing badly. Check your CAM batteries to ensure they are using only approved NIKON batteries as anything else will cause you lots of errors and potential problems. When you using the timer or remote options, remember these are controlled by battery as well, radio frequency, and radio wave lengths. When you press the button to take a photo, inspect the button, press firmly for a second and release. If your button is not performing the way it should, inspect it to see if any wear and tear is visible to you. Check free deprey around the button such as DUST, HAIR BUILDUP, and small particals that are hardly visible to the human eye. With very low velocity pressure air, blow around the shoot button as build up will cause the same error your experiencing. I SUSPECT THE NEWER CARD IS NOT COMPATIBLE AS THE OLDER CARD IS
Jan 25, 2011 | Canon PowerShot A610 Digital Camera
Asko Dryer t760 program menu won't change or is frozen The program menu is stuck on one setting, and the P1, P2, P3, P4 buttons don't change the program. When I try to reset the program (by pressing...
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 18, 2010 | Asko T761 Electric Dryer
How to set the packet data setting for nokia 5310?
  1. Press Menu
  2. Choose Settings and select
  3. Scroll down screen to choose Configuration and select
  4. Scroll down screen to choose Personal config. Settings and select
  5. Now, press Add (visible if you don’t have a previous Personal Setting created) or press the Options button. when you have pressed the Options button, choose Add New. Then you will have several options to choose from.
  6. Now, scroll down and choose the Access Point and select.
  7. Choose option Access point settings and select
  8. Go into Bearer Settings
  9. Now, choose Packet Data Access Point
  10. Now, enter your APN address corresponding to your operator, then press OK
  11. Now, go back to the Personal Configurations Settings menu (press Back 3 times), where you now should be able to see an Access Point (or called My access point) selected.
  12. Now press Options button, and then choose to activate the Access Point.
  13. Now you should be able to access internet.
Aug 10, 2010 | Nokia 5310 Cellular Phone
I am not able to view my files from my computer option
i am not shure but make shure it a aloud to view
on the camera setting
Dec 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Problem with coolpix 8700 camera
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 28, 2008 | Nikon Coolpix 8700 Digital Camera
Safety lock enabled
In Tom Tom One 3rd Edition - Go to Change Preferences > Safety Preferences > Uncheck >> Hide most menu options while driving > Done. This should work!
Sep 25, 2008 | Tomtom GO 700 GPS Receiver
Date still doesn`t appear on the photo in my computer
You need to take the photos with the date option on, and it becomes a permanent part of the photo. You cant turn the option on and off dynamically. Use the cameras menu to turn the date on and you should be OK from here on in! Thanks!!!
Apr 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-M2 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
