Question about HP Officejet 4315 All-in-One Printer
Can't receive a fax
My office jet 4315 all in one isn't ringing at all
    Brigadier General:
  • HP Master
  • 3,614 Answers
first can you try this;
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test does the following:
• Tests the fax hardware
• Verifies the correct type of phone cord is connected to the device
• Checks that the phone cord is plugged into the correct port
• Checks for a dial tone
• Checks for an active phone line
• Tests the status of your phone line connection
The device prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test.
To test fax setup
1. Set up the device for faxing according to your particular home or office setup instructions.
2. Make sure the ink cartridges are installed, and that full-size paper is loaded in the main tray before starting the test.
3. From the device control panel, press Setup.
4. Press right arrow to select Tools, and then press OK.
5. Press right arrow to select Run Fax Test, and then press OK.
The device displays the status of the test on the display and prints a report.
6. Review the report.
• If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause problems faxing.
let me know.
Posted on Jan 21, 2009
  • 45 Answers
Hi Milton,
Please check teh following link to resolve the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01506321&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank U
2 Suggested Answers
hashir4u
  • 79 Answers
SOURCE: Fax Problem
turn the printer on ...
unplug the power cable without turning the printer off....
press and hold # & 3, keep them on hold ....
while holding these two buttons put the power cable back in ... and wait for a few the screen to come up ... the screen may go blank ... use the power button to turn the printer on ... try to receive the fax ...
if it will not work then try # & 6 .... remember take the backup of phone numbers if stored on the printer as it ll erase the memory of the printer ,,,
Posted on May 23, 2008
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Cannot recieve faxes but i can send them
It is set on "manual receive" rather then "automatic receive"....check your "reception mode" settings and set it properly
Jul 16, 2009 | Pitney Bowes 9920 Plain Paper Fax
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
I cannot receive faxes, I have misplaced my owners manual of course!
Check the phone line with a regular phone.
Do you have digital phone service?
Jan 30, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
HP Office Jet 5610v All-In-One
If it is a dedicated fax line.
Then make sure auto answer is turned on.
Then go to Setup/Menu> and press the right arrow key till you see basic fax setup>
Then press Ok> Then press the right arrow key and scroll to basic fax setup> then press ok.
Then scroll to rings to answer and set it to 2.
Then press cancel and come to the main display.
Press setup/menu> and scroll to advance fax setup> and scroll to distinctive ring pattern> and select all rings.
You should be able to receive and send faxes without any problem if it is a dedicated fax line.
If it is a shared line with phone, voice mail or answering machine then you will hev to get a distinctive ring pattern from your telephone service provider.
So that it can distinguish your Fax message and voice message.
If any problem let me know.
Sep 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp Office Jet 4315 cancell a fax number?
go to the fax number, then try pressing the X button. Other wise if u are ready to loose all numbers, just reset the machine
Jan 08, 2008 | HP Officejet 4215 All-in-One Color Photo...
I HAVE A HP OFFICE 4315 ALL IN ONE PRINT.. I CANT GET FAX AUTOMATICALLY
Set to fax, ring it from another phone, what happens? Count how many times it rings before answering (if it answers)
Do you have other things attached to it?
Where is the phone line attached to socket marked line or ext?
Do you use Broadband? Has the fax got filters attached before it?
Are there other phones in the house or has the fax a dedicated line?
DONT YELL
Oct 20, 2007 | HP Officejet 4215v All-in-One Printer
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
