Question about Casio Ladies Bracelet Digital Watch La670wega-9Ef
How do i turn the alarm off my casio LA670WEGA-9EF
Turn off alarm on casio db 360
First of all, there is a manual online at
http://support.casio.com/en/manual/009/qw2515.pdf
and this should answer all your questions. I keep losing these as well, and Casio watches are not all obvious.
As far as the alarms go, I read that there are six operating modes of the watch, and you move through them using the bottom button on the left edge of the watch. The Alarm Mode has "AL" as it's heading, plus a picture of a bell.
In this mode, you move through the five alarms and the time signal (beep every hour) using the right and left buttons at the bottom of the watch face. For each alarm (and the time signal), you can press the bottom button on the right edge of the watch to toggle the alarm (or signal) on and off. There are blobs along the bottom of this mode, indicating which alarms are on and off so you can tell when they are all off.
So if I can work that out from a manual, it should be even easier if you have the watch in front of you.
Enjoy!
Jun 19, 2012 | Casio DB360G-9A 30 Pages Telememo Watch
Casio 3092 how to turn off alarm
I am not sure if you want to turn the alarm off for good or just dismiss it when it sounds, so I will supply the link to the manual.
Now you will have access to instructions for all the watches functions.
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=3092&submit.x=33&submit.y=19I hope this helps.
Apr 01, 2012 | Watches
Can not turn off alarm
If you have Alarms on, you will see a small bar above the Alarm numbers (1 to 5).
Press the Mode button to get to Alarm mode. You will see Bell AL on the top. Use Reverse/Forward to switch to the Alarm you want to turn off. The Alarm number will increase/decrease on the right of the time.
Use the 12/24Hr button to cycle through the Alarm options.
When the Alarm bar is blank, the alarm s/b off.
Note: The Casio manuals are online.
http://www.manualslib.com/manual/221397/Casio-Db36-1av.html
Aug 19, 2011 | Casio DB36-1AV Wrist Watch
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
I cannot turn off the alarms
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, mechaism could be stuck.
Jul 01, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
How to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I can't turn off alarm on casio g shock
Follow this link: http://world.casio.com/wat/download/en/manual/ Download manual for your watch and read how to turn alarm off.
Jan 12, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Turn off alarm
go to alarm mode and choose the alarm (1-5) using the "forward" and "reverse" buttons, then hold the bottom right button down to toggle it on or off
Aug 24, 2009 | Casio DB36-1AV Wrist Watch
How to turn off the every hour alarm on my casio 593 watch
go to mode menu scroll it and find the alarm mode ,when you see in a display a bell it will alarm every hour but if take the bell display it will not alarm every hour..
Jun 25, 2008 | Casio Watches
Do not know how to turn alarm off on casio g shock watch
I had the same nagging problem on my GSHOCK 2816. The Casio manual was no help at all. What I did to turn my alarm(s)  (mine has 5 independant alarms) off is switch to alarm mode (as you are looking at the face of the watch, it's the bottom left button. I push it twice to get to alarm mode. My display shows the current alarm time, and then the number 1. If you hit the top right button on the watch, it turns this alarm off. If you hit the bottom right button, it cycles to the next alarm in the list. To set an alarm, just cycle to the one you want, and then hold the top-left button until you see it flashing, then use the right side buttons to adjust the time. Hope that helps. This was a big pain in the **** until I figured it out.
Apr 17, 2008 | Casio Watches
Casio Ladies Bracelet Digital Watch La670wega-9Ef Logo
98 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
