Question about Emerson DECT 6.0 Expandable Cordless Phone w/ Digital Answering
I have a dect 6.0 emerson phone and I can't dial out at all with it. I know its the phone itself and not my phone line. I can get calls in however.
Dect phone manual
Standby mode is when the phone is not on a call, you're not dialing one, and you're not doing anything with the menus. It's standing by, waiting for you to call or for someone to call you.
Aug 09, 2014 | Panasonic KX-TG4022N DECT 6.0 Single-line...
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
Nwhere is the plus sign on my emerson cordless phone so i can make an international call
The "+" is simply punctuation, used to make the country code stand out. You don't dial it, just as you don't dial the "-" in a local number.
May 20, 2012 | Emerson Lands Phones
My Emerson DECT 6.0 dials like a rotary
Since you declined to specify the model of your Uniden DECT 6.0 phone, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download a copy of the manual. Look for the section describing how to switch between tone and pulse dialing.
Aug 15, 2011 | Lands Phones
My phone has a dial tone, but when I make a call there is a short buzz and a response of "The number you dialed is not in service". I can't make any outgoing calls to anyone!... yet I can...
This isn't an issue with the actual phone. I would attempt to call a number that you know is working. Like a free 800 number from the television. If you are able to get through with that call then you should check that the numbers you are calling are in service. If you have the same problem with the 800 number then you need to get in contact with your phone company.
May 10, 2011 | Uniden DECT 6.0 Cordless Phone ID
My phone is working but does not ring when people call my number - i only know that they have called by dialing 1471
working! presume u mean phone has dial tone and your able to dial out. Dial 17070 to verify your number. Possible u have crossed line. Hope this helps - BTscott
May 08, 2011 | Doro DECT 540 Cordless Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Jan 07, 2009 | Uniden Cordless Phone
Emerson DECT 6.0 Expandable Cordless Phone w/ Digital Answering Logo
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
