Question about Honeywell Heating & Cooling
F12 what its mean
Spanner on display showing
2 Suggested Answers
  • 2309 Answers
SOURCE: My Citroen Saxo is showing a spanner symbol in the
service engine ie oil change
Posted on Nov 16, 2009
Testimonial: "Thanks for the quick response. Excellent feedback."
Spanner symbol has appeared on dashboard display .
service due or fault code that needs attention
run the fault codes to determine if there is a problem
Sep 09, 2017 | Cars & Trucks
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
I have a 1cm verticle stripe on my Dell Studio 1737 ?
Your lcd screen is going bad. You can verify this by plugging an external monitor to your laptop. if the external monitor shows without the vertical stripe it means the video card is good but your old screen is bad. If the external monitor shows the stripe then it means the video card is bad.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
May 02, 2012 | Dell Studio 1737 (Studio 1737-RubyR) PC...
Toshiba a305 s6841 wihte screan
White Screen usually means the screen is bad. Get ready to replace it. If you system seems like it booted up all the way but the screen is white, more than likely the screen is bad.
Apr 26, 2012 | Computers & Internet
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Spanner sign with 500,100 and 0
The spanner or wrench you are seeing indicates how many miles are remaining before your vehicle is supposed to have the oil changed. Normally this is about a 10,000 mile interval and may be reset after an oil change by following this procedure...
Do the following steps:
Move start switch to position "2".
Within the first 4 seconds after moving the start switch to position 2, press the reset button for the trip counter twice within one second. The display for the service request is activated for about 10 seconds.
Within these 10 seconds, move the start switch into position "0". The service request continues to be displayed.
Press the reset button for trip counter and keep it pressed.
Move the start switch into position "2".
Continue to hold the reset button for the trip counter pressed until the signal sounds and the new start distance appears in the display (it takes about 10 seconds).
Jun 18, 2008 | 2007 Mercedes-Benz ML320 CDI
No user manual
It means it needs a service call. Are there any letters or numbers on the display?
Sep 25, 2007 | Minolta DiALTA Di183 Copier
Heating & Cooling Logo
21 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
