Question about John Deere Garden
John deere 455 won't throttle back u after ideling
It's hard to start and has to be started at full throttle, but will run good then. After throttling down, it won't throttle back up again.
SOURCE: Engine throttling up and down continually
This is the classic symptom of improper air/fuel ratio.
There should be an adjusting screw on the side of the carburetor -- it has a spring at the base -- turn this with a screwdriver slowly back and forth to see which direction makes it run better -- take it from there...
Posted on May 09, 2009
panilling9
  • 284 Answers
SOURCE: john deere 2305/ the throttle lever goes back to
remove throttle lever assembly and if it is put together with a rivet?
take vise grip pliers and put in its jaws where it is connected or pivots at the rivet and squeeze it tighter at that point as it has worn with use. You will have to put out on it to make a difference
or if it is put together with a bolt ? its obvious
or if the throttle has indentations built in at certain points of travel then be sure the throttle assembly is tight enough to hit those and stay in that position
Posted on Jun 09, 2009
moretons
  • 155 Answers
SOURCE: john deere lt133 kohler 13hp starts ok then
Hi Sounds like valve clearences are out Yes they can be adjusted the settings should be at .004 thou on each.
Posted on Sep 12, 2009
nova2nv
  • 197 Answers
SOURCE: I have a 1988 318 John Deere garden tractor and it
If your rpm's are high/sluggish and slow reacting its do to your govenor inside your engine needing to be fixed.There is a plastic housing with fingers on it that will break and allowing metal balls to free float.Another problem with them is that the washer under the retaining ring will fail or loose tolerance,also located inside engine.
Posted on Nov 16, 2009
wireguy212
  • 1627 Answers
SOURCE: John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Posted on Jan 19, 2010
John deere 455 keeps dieing
Clogged pilot jet inside the carb. You need to remove the jets and ream them so they are clear. If it starts and then dies as soon as you try to throttle up, then it is the pilot jet.
Apr 25, 2017 | John Deere Garden
John deere - 455 Diesel
check your seat safety switch
Nov 19, 2013 | Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
Car won't keepidel1989 300e Car won't keep idel, starts up runs for a while but cutsoff
first ensure your spark plugs, wires, cap and rotor/coil packs are in good shape. once thats done check for a check engine light, sometimes they come on then go off but a code will be stored regardless. once you have made sure your getting good spark and there are no trouble codes the issue is most likely a dirty throttle body or fault IAC (idle air control) valve or throttle positioning sensor. hope this helps, good luck
Mar 15, 2012 | 1989 Mercedes-Benz 300-Class
I have a John Deere RX 75 that worked perfectly fine. I just did maintenance by greasing some fittings and I sprayed WD-40 on some of the moving parts under the seat (throttle, levers, etc.). After I...
If it's a hydrostatic, most likey you pulled the manual over-ride (only way to move the tractor manually). By leaving the over-ride level in the disengaged position, the tractor will start & run, but not move forwards or backwards. Correct by closing the the lever to it's closed (operational) position.
Oct 18, 2011 | John Deere Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
