Question about Remington Chainsaw Pl-4 Pl-5 Pl-55 Sl-11 Clutch Drum
Need clutch for sl 11 remington 65 - Remington Chainsaw Pl-4 Pl-5 Pl-55 Sl-11 Clutch Drum
Old Remington 12 Ga. Auto Loader on Browning Frame. Serial No. 238817. Year Made.
are you talking about the old Model 11 which is a copy of Browning A-5? more details would help. But it probably has a solid rib (amazingly, those were machined in one piece with the barrel, not soldered on). Many have had barrel problems. Look closely at yours, especially for pitting in the bore and bulging at muzzle.
The model 11 remington shotgun was produced from 1905-1949 when it was changed to the 11-48 dating your shotgun to exact year MAY be possible if theres a date code on the barrel left side ,,this would proably be a 2 letter code.. and should be near the point where the barrel meets the receiver. Without it it's anybody's guess.
condition means the most for values but you can pickem up for a average between 200-350. for insurance purposes 400 if in good working order.
Model 11?
Feb 26, 2018 | Remington Optics
Remington Model 11 436731
Dating and value in the link. Value always depends on condition and the barrel is in proof. It looks a lot like the Browning 5 shot auto I used to own.
Remington Model 11 Google Search
Nov 20, 2016 | Remington Garden
I have a Remington electric versa saw rm1635w and the chain won't spin around the bar what do I need to get it running again
there is a safety clutch that you disengage when finishing the cut
it disengages the chain from the motor drive by a dog clutch
pull the safety bar back towards the trigger and the chain will cut
if you leave the finger on the trigger and the chain jams in the cut , you push the bar forward and the motor spins free
if that doesn't work take it in for a fix as that clutch is failed
Nov 16, 2016 | Remington Garden
Remington chainsaw 1965 65 cc Gas mix is
50-1 possibly will work well .
Jul 26, 2016 | Remington Garden
My clutch ticks when shifting gears on a 1999 saturn sl. Also revs really high.
1. how high? and at what speed? 30 mph? 65 mph? 75 mph?
2. are you scheeling with the car? are you raceing?
Apr 28, 2010 | 1999 Saturn SL
The motor runs good but the chain does not move. It ca be moved easily by hand.
No clutch on this make electric chainsaw. I think a stripped gear. Remington is no longer in production and parts may not be available. I need a model number to verify both possibilities. Below please.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Electric Chain Saw
Where can I get a manual or take down instructions for a Remington model 11.
The Remington model 11 and the Browning Auto 5 are pretty dang similar. Both made during the same time. The take Down is very Similar.
Here is a link to the take down/user manual for the Browning Auto 5.
LINK
However, if that makes you uncomfortable, Instructions are available in the Gun Digest Book of Firearms Assembly/Disassembly Part V: Shotguns for the Remington Model 11.
Hope this helps.
Oct 15, 2009 | Remington Sport & Outdoor - Others
Parts needed for a remington SL4
Hi, if you have access to a computor goto GOOGLE type in remington chain saws electric press search and it is all the models ,parts and distributors easy go for it ,any more help needed just come back to me. youdoit
Aug 13, 2009 | Garden
How to disassemble a model 11 remington shot gun
i'm uncertain if this is indeed the correct manual so please have a look and see
http://www.remington.com/pdfs/om/om_11001187.pdf
Robert
Please take a moment to rate this solution... thanks
Jan 31, 2009 | Sport & Outdoor - Others
Remington Chainsaw Pl-4 Pl-5 Pl-55 Sl-11 Clutch Drum Logo
48 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
