Question about Kitchen Ranges
I need a user manual for neff enr d 8990 gb extractor hood
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
heavyt15
  • 91 Answers
SOURCE: I have just bought a neff extractor hood d8600n0gb
Some do and some do not..call the store ...see if you geta freebie or discount
Posted on Nov 04, 2009
apart4u
  • 213 Answers
SOURCE: I have a NEFF D FX41 4 extractor hood, neither
this could be the pcb
You-Tube video "8eLuShj-RAg" placeholder (do not delete)
For all Free appliance repair videos visit our VIDEO TUTORIALS
Posted on Jan 14, 2010
SOURCE: Hi I have a Neff E-Nr No D9610NOGB FD 8401
Hi the problem is not solved but your free advice is not free and I do not wish to subscribe.
Regards
Posted on Jan 15, 2010
SOURCE: We wish to remove our Neff GB 5030 extractor fan -
Strangley enough I have just tonight fixed the switches on our 25 yr old GB 5030 !
When you say they are not working do you mean nothing happens when you push them or are they not staying in (as mine were)
If the latter I have solved mine with use of cleaners and electrical grease - if you want full details let me know
Posted on Jan 16, 2010
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
USER GUIDES FOR NEFF OVENS
http://customerservice.neff.co.uk/product-advice
Use link, click on product advice, then click download manual, enter Enr (U1422s0GB) to access II (installation) IU (User manual)
Apr 12, 2013 | Neff Ovens
I have a B4540 and I do not have an instruction manual as it was an ex display model from my dads showroom. I have always cleaned it by hand as have no idea how to set the self clean programme. Please can...
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Use this link, type in the full ENr and you can download a PDF file of the user manual (IU)
Mar 14, 2013 | Neff B4540 Stainless Steel Electric Single...
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
Dec 08, 2012 | Neff Microwave Ovens
Hi I'm after a manual for NEFF 47442 cermaic hob please
This not the full ENr number required to get the instruction manual. Most NEFF hobs ENrs start with a T...Once you've found the number (should be on the base of the hob, which will mean removing drawers or possibly an oven to check) use the linkhttp://www.neffcustomerservice.co.uk/
go to the bottom left of the page and click on 'instruction manual download' this will open another page where you can enter the Enr and then get the user manual. either to store on the computer as a PDF file or to print off.Hope this helps.Roni
Sep 19, 2011 | Bosch Axxis WFL2090UC
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
Sep 02, 2011 | Neff B1644 Electric Single Oven
We wish to remove our Neff GB 5030 extractor fan - the switches have stopped working and replace it with a consort 600 fan that we have been given. We can't see how we disconnect the old fan. Thanks.
Nov 21, 2009 | Kitchen Ranges
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
Kitchen Ranges Logo
199 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
