Vintage B&O audio cassette deck Beocord 9000 does not play, fast forward, rewind tape
All functions seem to work: display lights, tape type light, recording levels lights, capstan seems to turn but tape does not move.
  • Kemal Saiki Jan 12, 2013
    Could be a belt problem in the cassettte transport mechanism or lubrication. What sort of lubriicant is used in cassette deck transport mechanism?
5 Suggested Answers
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
  • 31 Answers
SOURCE: A. REAL SPEAKER CONNECTION B. CASSETT RECORDER NOT ENGAGING
A Real Speaker Jacks..
There should be a switch position on your system that you move to allow the sound to come out to standard speaker configuration or to multiple speaker configuration.
This switch may be on the front or rear panel.
Please have alook to see if its there....
Its possible the these Real speaker jacks are not wired to anything inside the amp system, and are there for use on a different model where the selector switch is supplied.
B Cassett Deck..
The clicking is caused by the motor trying to drive the wheels that turn the cassett tape.
It sounds like something is jamming the internal drive mechanism.
The drive belt may have come off or is stretched and is slipping.
Have a good look inside the front slot and you may see one of these items described above happening..
It may have to be serviced at a workshop.
Cheers From YUBEUT.
Posted on Dec 04, 2007
nate_stow56
SOURCE: No sound from tape player
HEY EVERYONE WHO HAS A PROBLEM WITH A RCA RS2640 STEREO!, if u have this problem all you do is take it apart and then find the control panel and get like a credit card or something, you should see a chip placed near the control panel all you do is get the credit card and gently scratch it with a credit card for 30 seconds and then it should work!!
Posted on Jan 23, 2009
Grubhead
  • 5056 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
The tape cassette doesnt rewind
This can be a toughy without having the unit but the Chinese decks (After 1992 vintage) all but the expensive units and here are the makes they are using the same mechanism. This deck has two belts and the one is from the motor to the capstan and the other is fed from the capstan (under the flywheel) to the fast forward and rewind mechanism. If the fast forward is okay and the tape plays okay then the belts sre working and the rewind gear is out of position and if you are lucky then all you do is to push the left reel spindle in and replace the small plastics circlip which by the way do come loose sometimes. If that does not help then is it sometimes cheaper to buy a cheap portable set and fit that into your deck The motor on some is on the side and others sort of on top depending if it is a top loading or front loading machineI have seen these same mechanism in the following makes Philips Telefunken Akai Sony Teac Supersonic Roadstar and so on I hope this help.
Oct 08, 2014 | Audio Players & Recorders
Play button and fast forward will not stay down,click down momentarily but then click off again--- fast rewind works perfectly
No Idea- you need to state a model and brand to get an answer. Could be broken keys if it is a piano type button cassette deck.
Jan 21, 2014 | Audio Players & Recorders
I have a Sherwood DS1150 tape Deck. Problem Cant open Cassette Door, tape is inside . Will not rewind or fast forward. Wont play. Any advise
Very likely the tape is wound around the capstan.
You may have to get at it by taking the unit's case off.
If I am right you might have to destroy the cassette unless you are very careful. Or, at least, have to cut the tape so as to unwind it from the capstan.
You could also try to open the door just enough to lift it up and off ... as if you were going to clean the tape heads.
Mar 12, 2012 | Audio Players & Recorders
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
49 people viewed this question
 Grubhead
Grubhead
