Question about Kingston DT6000/16GB 16GB DataTraveler 6000 USB 2.0 Flash Drive DT6000/16GB
How do I remove the write-protection from my Kingston DataTraveler 6000
  • 95 Answers
SOURCE: Removing of write protected from kingston USB
is there a small switch on the side of the drive, which can be moved. its basically for write protection.
Otherwise its a problem with drive, and you need to format it. If that is not working then your drive has got corrupted and needs a replacement.
Posted on Jan 27, 2009
laikexpert
  • 281 Answers
SOURCE: i cant remove the write protection of my kingston
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 28, 2010
SOURCE: my datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Posted on Feb 14, 2010
SOURCE: my 8gb kingston datatraveler apears good but cant open at all
may be toomuch virus
Posted on Apr 17, 2010
bronk50
  • 27725 Answers
SOURCE: i have a DTI/64GB Kingston
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Posted on Feb 18, 2011
WHAT IS WRITE PROTECT?
look on the side of the usb there is a little button that you push one way or the other to remove the write protect
Oct 27, 2012 | Kingston 4GB DataTraveler I Generation 3...
How to remove write protection from kingston usb drive
From the Kingston website:
DT101G2 - DataTraveler 101 G2 FAQ
Is there any security or write protection feature available for this DataTraveler? Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective. Contact Kingston Technical Support for further assistance.
May 31, 2012 | Kingston DataTraveler 101 G2...
How to remove write protection from datatraveler 32gb
To remove write protection:
  • Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
  • Navigate to the following path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
  • Double click the key WriteProtect in the right pane and set the value to 0
  • In the Data Value Box, press OK button
  • Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer.
That is it, done. Goodluck
Jun 16, 2011 | Kingston Technologies 512MB DataTraveler I...
Kingston datatraveler 8G shows write protection error, contain a virus outorun.inf, cannot save, cannot be formated and cannot delete. Please help.
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
Kingston datatraveler 512 MB is write protected. there is no switch.i cant format del data
Well u cannot do nothing than to kindly replace it. If u r able to get it working, it'll tell u same thing after sometime. 100%sure
Feb 07, 2010 | Kingston Technologies 512MB DataTraveler I...
Kingston DT 101 II Usb Device become SKYMEDI USB drive
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
May 26, 2009 | Kingston Technologies 512MB DataTraveler I...
REMOVE WRITE PROTECTED PENDRIVE
Should be a switch on the pendrive. Just push it in opposite side. That will disable the write protection.
Apr 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingston DT6000/16GB 16GB DataTraveler 6000 USB 2.0 Flash Drive DT6000/16GB Logo
108 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
