Question about Panasonic DP-C354 Copier
Won't Print We have an office and multiple computers are networked to our printer. For some reason, when one person tries to print from ZipForms on her desktop, it won't print. It will print everywhere else. We have codes for each person to keep track of how much they are printing and copying. Her code is in, everything under the printing properties is set, it just doesn't go through with the printing. We can hear the printer think about it, it doesn't finish the job and print though.
    Sergeant:
  • 284 Answers
Check to make sure you can ping from her machine, then check to make sure you have the right driver , if you do make sure her code is programed in the driver. if it is then try to reinstall the driver..
if all else fails try using system restore on the computer to a date you know was working because it could have been something that was installed that is blocking it now
Posted on Jan 22, 2009
Make my Lexmark x5340 be wireless'
Is this a wireless printer? Is it being used for a large office or a small home type office? If you are using it for a home office and have multiple pcs, then you can setup a homegroup. A homegroup is like building your own personal small network. You will be able to share and print documents between your computers. Once you setup the homegroup, on one computer, then you will have to add the other computers to the group using the access code that the first computer will provide. Be sure to enable printer and file sharing when setting-up the homegroup. Once setup, you will be able to print your documents from any connected printer on your network. It's not wireless but it might help to solve a print sharing problem. Good luck. How To Set Up Homegroup Sharing Plus Printer Sharing
Dec 22, 2014 | Lexmark X5340 AllInOne InkJet Printer
Bizhub c550 loosing network access
does the copier have a static IP address or is dhcp meaning ever time the network is turned on the copier get a new/different ip address. Copiers love static so recommend your it person assign one.
Feb 11, 2014 | Konica Minolta Bizhub C550
Connect multiple computers to printer
Does This printer have the ability to print over a wireless network? If it does than you are able to print using multiple computers this way. Otherwise try this: http://m.wikihow.com/Share-a-USB-Printer
Jun 12, 2013 | Televison & Video
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Our HL-5250DN won't show up on the network as a printer anymore, but I can reach it's admin page? It's driving me crazy to try to figure this one out. Nothing about the status given on the admin page seems...
Just reinstall the Printer on the Main PC install/Setup all software again, set for shared, Then, go to the clients PC's & set up that printer for NETWORKED Printer, Browse for it... should get you back. Installing a network printer allows multiple users and computer to share a single printer, rather than having numerous personal printers throughout the home or office. When installing a network printer, make sure it is located in a centralized place so that all users can access it conveniently, then install the software on each machine. You may find that newer versions of Windows may already have the necessary drivers installed. Finding the Printer on the NetworkTo install the printer using an IP address, go to Start>Control Panel>Printers and Faxes and then click the Add Printer icon. Next, clickCreate a new port, then select Standard TCP/IP Port from the drop-down menu. You will then be asked to enter an IP address. Enter the IP address of the print server and click Next. You will be asked to select the printer manufacturer and the model from the list. If you do not see your printer listed, insert the disk that came with the printer and click Have Disk.
If you do not know the IP address of the printer, you can sometime select Browse for printer in the beginning of the process. If the networked printer is attached to another computer is being shared, you will need to enter the name of the computer followed by the share name of the printer. For example: \\computername\printername.
Spending extra on a network printer can save you money in the long run. Network printers can be higher grade and print cartridges can last longer than personal ink jet printers.
Feb 16, 2010 | Brother HL 5250DN Laser Printer
My printer canon ir2022n network printer does not print from my new vista business OS computer
Windows sharing based printers are dependent on the computer where the printer is attached. This means that if the computer is turned off, or is in the sleep/hibernate mode, then all the computers that can print through that server will not be able to print. To solve this issue you can use external print servers to share printers in the home/office. External print servers are connected to the router which allows it to be available on the network without being dependent on any other computer system. External print servers are available in both wireless and wired versions, and the choice between those options is based on the needs of the home or office.get more information and help for Network Printer Configuration .Hope this helps you.
Oct 13, 2009 | Office Equipment & Supplies
Can't scan with mfc-7840 w, has worked fine for months, on laptop with xp, was working in another office for last 10days, came back to home office and it can't recognize device at all I can ping IP no...
I had a similar problem. I was able to print and scan for months and then all of a sudden could not scan anymore (from printer or through software interface). I then found out that the IP address for the scanner was not set properly. To fix this, goto control panel and scanner and cameras. Right click on the MFC7840W and select PROPERTIES. On the network setting tab, make sure that the IP address is the same as that on the MFC7840W.
Mar 31, 2009 | Brother MFC 7840W Printer
Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Aug 29, 2008 | Brother MFC 420CN All-In-One InkJet...
C5280 won,t print
I had a problem with my C5280 installing another copy of itself when I restarted my computer. Check to see that you don't have multiple copies installed and are possibly trying to print to the wrong one.
Aug 28, 2008 | HP Photosmart C5280 Printer
Panasonic DP-C354 Copier Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
