Question about Admiral Washing Machines
Admiral washing machine model ATW4475TQ0 won't agitate.
Washer will fill, but won't agitate. It will drain and spin if the agitate cycle is skipped.
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
Yozzer6821
  • 116 Answers
SOURCE: Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Posted on Apr 18, 2008
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
SOURCE: Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Posted on Jan 12, 2011
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Posted on Jul 23, 2011
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
