Question about Watches
Where can I find a replacement strap for a Croton Nicolet Automatic Sharkskin Watch (NT322139BRBR)?
The sharkskin strap broke at either side of the case. The strap is 26mm wide but only 10mm at the case/lugs. I'd prefer a replacement sharkskin but would settle for a rubber strap with that "reverse tapered" dimension.
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com
/products/H45820.jsp
- Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
escapement
  • 2334 Answers
SOURCE: AR 1029 armani watch replacement strap
All the info you should be able to find here:
www.emporioarmaniwatches.com
You can email, get customer support, call by phone or place an order.
If you can't find it there, try to buy it on ebay. Alternatively you can visit online shops by typing the name and model of your watch into your browser.
Posted on Jan 19, 2009
escapement
  • 2334 Answers
SOURCE: Ironman Triathlon Sleek Ladies Watch Band Rubber Strap Discolors
Unfortunately there is no way to get rid of that discolouring.This is due to sunrays+swetting+chemical composite of strap material. Would be too long to explain how it works, so, here is the link where you can order the new strap:
http://www.timex.com/gp/node/n/256542011/ref=sc_bb_c_11_251377011_15/190-2521384-6105829?ie=UTF8&node=256542011&no=251377011&timexBrand=core&me=A1S5XB33AHYRMX&clicked=center-1115
Rate me, please.
Posted on Jul 22, 2009
  • 6 Answers
SOURCE: the strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Posted on Mar 17, 2010
Battery for SP299131YLDW
You may have to open it up and find the type number on the battery.
May 16, 2016 | Croton Watches Croton Womans Brass Gold...
Tip
ARMAND NICOLET watch manuals.
Follow this link:http://www.armandnicolet.com/armandnicolet.asp You have to click on MEMBERS tab and subscribe to be allowed to download ARMAND NICOLET watch manuals.
on Mar 03, 2010 | Watches
I bought a Croton watch style is Croton Automatic limited edition 0202/1000, 35 jewels, I'm having a problem with it self winding, the mechanism in the back seems to be jammed, it will not spin easily...
It sounds like you have be sold a lemon!
If you have recently bought it and you have a proof of purchase (and it is still within the warranty period) then you should return it for repair/replacement.
Apr 01, 2011 | Croton Watches
I have a Croton watch. It is a automatic.I can't get it to run.I was informed that the watch had to be wound. The crown{stem} has four settings.I shak it and it runs for about 15 seconds
In the first position (closest to the case but not screwed down if it's a screwdown crown) wind the crown clockwise about 40 turns and it should run fine. The automatic winding system relies on wrist movement to spin a weighted rotor that winds the watch. When you're not wearing the watch or not moving much when you do have it on, it will run down and you have to manually wind it to get it going again. If you wear it everyday and are reasonably active you may never have to wind it but take it off for a day and you will.
Apr 20, 2010 | Croton Automatic Watch Day/Date Swiss...
Nicolet Men's Metrosphere Swiss Automatic Stainless Steel Watch the day is not in English, currently it shows MIE, can I set this to show the days in english?
I don't know this watch specifically but typically the following applies:
To set the day/date you set the crown (winder) to the first position (second posn is "set hands) i.e. pull out one stop, and rotate winder eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Jul 17, 2009 | Watches
Can't get my croton watch to work.
Jan 05, 2009 | Croton Watches
Prague 49011G, automatic wind watch - stopped ticking
I also have a Prague automatic watch (not the same model) which I purchased in 10/06 and have had it repaired twice. If you purchased the watch new, a little white warranty paper should have accompanied it. If not, you might be out of luck. Anyhow, each Prague has a two year warranty. My warranty instructed me to send the original receipt, a check for $10 (for return shipping) and the watch to Croton Repair; 195 Anderson Avenue; Moonachie, NJ 07074. There of course is no phone number to call them. Make the check out to Croton Repair. The warranty also says they do not guarantee they will fix the watch, but they guarantee they'll send you the watch back if it cannot be repaired. It took about 5 weeks and my watch came back repaired. Unfortunately about 6 months later it broke again, same exact problem (no long self-winds, ticks or keeps time, my watch also has a diamond at each hour, two of which fell out)... I've seen a lot of the issues people are posting seem to be the automatic watches not working. Probably duds, the inner workings seem to be very sensitive.
Dec 24, 2007 | Watches
Croton automatic watch, band problem
Unless you have the appropriate tools for the job, it is likely that you will mark or damage the links taking them out yourself - any reasonable jeweller will be able to perform this service, normally only costing a few dollars at most. You could also return the watch to Croton to get this done if you prefer; http://www.crotonwatch.com/contact_us.aspx If you are still determined to do it yourself, then it is fundamentally just a matter of identifying the removable links (they will have a small screw head visible on the side), buy the correct size screwdriver(don't get a cheap one, it will do your watchstrap no favors) then it is simply a matter of unscrewing the link pins required, reassembling the pin where you wish to rejoin the strap - use loctite or similar to keep it from undoing, but be careful not to get this in the moving parts of the strap. if you can post a close up picture of the removable links from all sides, then i could talk you through it in more detail. Hope this helps :)
Apr 18, 2007 | Croton RC311065RGRG Wrist Watch
Watches Logo
48 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
