Question about Nikon D80 Digital Camera with 18-135mm Lens
I have a Nikon D 200 Camera that gives a grinding noise before it gets focused, and then it stops and works ok
I went through the resets and then it seems to work ok,.Just want to know what the high pitch grinding noise is
    Sergeant:
  • 321 Answers
Ur VR is GONE or do not keep ur mobile near camera while using it
Posted on Jan 10, 2013
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
SOURCE: Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Posted on Feb 20, 2009
pixeldawg
  • 71 Answers
SOURCE: My nikon 70-200 stops focusing
Nice lens too... I would take a good look at the electrical contacts on that lens. If OTHER lenses are truly working correctly, you have eliminated the camera as the cause and need to look at that specific lens. The first thing that I would try is taking a pencil eraser and rubbing all of the contacts with it. This will often clean the contacts of dirt and grime and clear off any "coating" that may have accumulated over the metal portion of the contacts. Barring this, I would send the lens to Nikon for servicing. It is a high percision device and taking it apart yourself is NOT recommended.
Posted on Jul 10, 2009
  • 181 Answers
SOURCE: d80 auto focus broken
AF lenses normally have a subtle grinding noise when used. Make sure your AF switch is turned on. If this still does not work, you may wanna consider bringing it in for repair
Posted on Jan 04, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: D40 with a Nikon AF-5 DX 55-200 lens will not auto
I had a similar problem with one that I bought. and come to find out, the gears internally in the lens where broken. I would return the lens, and get another one. Also when you go to buy a lens for your camera make sure that you bring the camera with you to test the zoom before you buy it.
Just FYI you also need to remember that with a smaller zoom your focus time will be slower, and it will take getting use to, unlike the larger zooms, you are trying to focus on a large area but being very detailed at the same time.
Posted on May 05, 2010
After charging camera makes a strange noise
it may be the focus resetting to its start position for the next picture..
Mar 06, 2014 | Nikon Coolpix S6100 Digital Camera
My 18-55 and 55-200 lenses on my D40X will only work in the manual focus mode. (In other words, the autofocus mode has stopped working.) The problem first developed with the 55-200 lens and later with the...
I would check to see if the lenses work on another Nikon digital camera.Double check the A/M mode switch on both. Does it feels solid or mushy when you flip it back and forth?
I will say that both lenses use the same auto-focus gear assembly which can fail over time. Nikon only sells the assembly as a unit, so even if one of the small gears is broken or damaged, the whole thing gets replaced. You cab send them to Nikon or a trip your local camera store may be in order.
Jan 06, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
D80 auto focus broken
Dec 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon DX 55-200mm lens
Hey Embroiteri,
I hate giving out bad news, but it sounds to me like your focusing motor is broken. I am of course going on the assumption you have the camera set to AF mode, and the lens still doesn't focus. In my experience with SLR lens is that if there are scratching or grinding noises when either focusing or zooming there is almost always something broken inside.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
Apr 13, 2008 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Feb 24, 2008 | Nikon D40x Digital Camera
Nikon Auto focus problem with the 18-135 KIT lense
I had this problem and just realised it today. I found out that it was a a settings problem. What I had done without realising was I had my "AE-lock" button functioning as "AF-ON" which meant that my autofocus would only turn on when I held the shutter half-way and pressed that button. Once I turned this function back to its original state of "AF-Lock" as opposed to "AF-ON", it worked fine.
My symptoms were: • soft mechanical noise when holding the shutter (i thought it was trying to focus but couldn't. I thought the mechanics for the AF were faulty) • Couldn't take photos unless they were in the set conditions (which makes sense because it was locked on a certain setting until I pressed the AF-ON button).
My camera is only a few months old so I wasn't convinced it was faulty/broken. Make sure you test all of your settings and go through each of them before you chalk it down to equipment error.
Hope this helps.
Dec 03, 2007 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
24 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
