Question about Hitachi 61HDX98B 61" Rear Projection Television
61HDX98B I was given this TV and it has a built in Directv Receiver. I ordered a card for it, not yet in. I was wondering if the tv should work without the access card? I can't play a dvd, vcr etc. The tv turns on but no signal. Shouldn't I be seeing something? I opened the back of the tv and I see an LCD light flashing "protect"???? not sure what to do?
    President:
  • 3,130 Answers
Switch to an aux. or different input. You will need an original replacement remote to do this with. If you do not have an original replacement remote, you can find on here:http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=61HDX98B&brand_pn=HITACHI_61HDX98B&mode=large&uid=11834718300770 If you do have an original remote, you will need to press the input button on the bottom left hand corner of the original remote to switch inputs Good luck
Posted on Jul 03, 2007
  • 934 Answers
Contrary to the idea that a remote may solve the problem - the LED flashing on the signal board indicates a potential short and possibly why you had the TV given to you to begin with... This is a DP85 Chassis that has a couple of traps in it - like the bulletin PT99-04 explaining that improper inspection of the main chassis can damage the unit. My suggestion would be take it to a reputable shop for an estimate and don't run it too long or you may risk more or severe damage that will be quite costly to repair...
Posted on Jul 05, 2007
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
I want to run a live TV threw my acer aspire Z5700 with directv how do I do it
Hello booche!
Directv provide free software so that you can stream live TV over your home network from your Directv Receiver to your computer. I think given the particular model of All-In-One you are using, this is perhaps the simplest and best option for you.
Here is a direct link to the Directv website page which gives detailed instructions: http://www.directv.com/DTVAPP/content/directv/technology/directv2pc
I hope this works for you!
Mar 05, 2011 | Acer Aspire Z5600 PC Desktop
How do i hook my direct tv to the philips tv
This is what you'll need to do this:
  • Your DirecTV receiver, DirecTV access card, and your DirecTV satellite dish.
Step 1: You need to write down the serial number that is on your DirecTV access card onto a piece of paper that you will need for future reference. You'll need the number to activate your service with the DirecTV company. Now take your access card and insert it into your box, there is a slot either on the back or front side in which the card with enter.
Step 2: Plug the cable line that is coming from your satellite dish into the "Satellite In" plug on the back of your receiver box.
Step 3: Look for the "Out to TV" port on the back of your receiver, and use the proper cable, which should come with it, to plug it from the receiver into the proper port in the back of your TV.
Step 4: Power up the receiver and your TV (after plugging in the power cable and all) and tune into either channel 3 or 4, depending on where you live.
Step 4.5: You may be prompted to plug in a phone line, in which case you would need to plug in a phone cable into the back of the receiver, but this is only required as a one time thing, you may unplug it after activating your account.
Step 5: Once everything is set up (which it should be at this step), call DirecTV at 1-800-531-5000 to activate your access card, and you will need to use the serial code you copied down from it.
Step 6: After your access card is activated, enjoy watching on DirecTV!
Jan 03, 2011 | Philips Televison & Video
Can I take the access card out of a standard Directv satellite receiver and put it in a new Directv HD DVR (HR20-700) without any problems?
You can do that but it still won't work. You have to make the changes with Direct TV in person for them to "authorize" your new receiver. More is needed than just the card.
Jun 23, 2010 | Directv HR20-700
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Direct receiver is not responding to remote
if you go to: http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.450
it has different remote codes. you would have to select "satellite setop box" also you need the model # of the receiver which can be found (normally) behind a door on the front panel of the receiver on a sticker (where the access card and reset button are) if its not a directv receiver, (hughes, etc) then it would probably be on the back of the receiver you would see a sticker with the model # of this receiver.
the first code should be 00001 follow the instructions on how to program on that website.
Apr 19, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Rf modulator for direct tv box
Re: Hiding the direct tv box
Your primary concern with hiding the receiver is how it works with the remote control. By default, Directv remotes use an IR (infared) beam to communicate with the Directv receiver, and this means there must be clear line of sight from the remote to the receiver. However, you can possible use RF (radio frequency) to transmit signals instead. This would allow you to pretty much hide the receiver anywhere you wanted. Currently, standard receivers do not have this capability, but DVRs and HDs do. Contact Directv customer service and ask if you will need to order an RF remote (there may be a charge). https://forums.att.com/t5/DIRECTV-Installation/Hiding-the-direct-tv-box/td-p/4425309
Jan 02, 2018 | Televison & Video
DirecTV Venezuela
no it wont sorry. once a card is activated in a receiver it is married to that reciever. only directv sends out new cards to replace damaged ones. If you buy a new receiver it will come with a new card that you will have to activate
Jun 23, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Open Questions:
Hitachi 61HDX98B 61" Rear Projection Television Logo
162 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
