Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My shark vac and steam wont pump water to steam
When you turn the machine on you hear the pump pump the water to the heater.....now when I turn it on there is no sound what is wrong with it now ?????
  • 18 Answers
Likely you have used tap water and there is now mineral deposits blocking the flow. I posted a video on how to take it apart to clean it.
www.youtube.com/watch?v=S4NglGXVv50
ALternatively, people have had success in putting CLR into the tank or Vinegar and pumping the unit and leaving it overnight in attempt to clear the blockage that way. I gave up and just took it apart and found a significant amount of mineral deposits blocking things up.
Posted on Jan 11, 2013
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
SOURCE: Euro Pro Shark Steamer #S3325. Will not steam
Have you tried CLR?
Posted on Aug 11, 2009
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
heatman101
  • 43501 Answers
SOURCE: My shark steam mop will not start steaming. Are
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
f
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Posted on Sep 26, 2010
Having problem with steam not coming out to do floors
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having problems with your Shark Steam Vac. One solution you can try is to create a solution of approximately 50% water and 50% CLR (calcium, lime, and rust).
Put the solution into the water tank of your vacuum and let it sit for awhile. Over time your vacuum may have developed a build-up of calcium which is blocking the pores that release the steam. This solution should break-down the calcium and allow steam to flow out of the vacuum.
If you do not have CLR on-hand, an alternative found in most kitchens that can be used is vinegar. Again, make a solution of vinegar and water and allow it time to sit in the tank attached to the vacuum. Then try running the machine.
You can purchase replacement parts for your Shark direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/shark.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 06, 2015 | Shark Rotator Vac-or-steam 2-in-1 Hepa...
My shark vac and steam model mv 2010 pump wont come on help?
If your not using distilled water the machine is probably loaded with mineral deposits from hard water and is plugged. you can try running some vinegar through it which may or may not work depending how plugged it is.
Oct 22, 2013 | Shark Vac Then Steam Mop MV2010 NEW
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
I have a shark steam and vac and it has stopped steaming. the heater is warm so it is working but no steam??
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Feb 20, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mop will not steam when pumped. Just the cold water in the tank comes out.
heater is broken...
heatman101
Jan 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark vac is getting hot but hardlthe steam is coming out to
heatman101
mn
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
285 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
