Question about Konica Minolta Bizhub C224 Color Copier Printer Scanner
No specified folder error - Konica Minolta Bizhub C224 Color Copier Printer Scanner
    New Friend:
  • 16 Answers
When setting up scanning to smb check the file path you are sending the document to. it is easier to store the folder on the c:\ drive under scans. Also ensure you have the correct username and password for the pc that has the file stored on it and set the NTLM setting to accept v1/v2.
Posted on Apr 08, 2013
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Tip
All Problems have ONE solution and that is: www.longPathTool.com Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
Scansoft setup cannot continue becasue of the following error: the system cannot find the file specified. please contact the software vendor or try again at a later time.
Where are you setup files? If you have a CD/DVD, or a folder then you need to point the setup to that folder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Aug 16, 2014 | Computers & Internet
Error 1320 when installing checksoft
Error 1320 the specified path is too long: example C:\ProgramData\Documents\Checksoft
Create a folder such as C:\Checksoft then when installing tell it to install in that folder.
Jan 23, 2014 | OnDemand Avanquest Checksoft Home and...
Solution to Toshiba TVAP error (0x8146045B)
Use the "Options" button, select a folder to extract the package, unchek the auto-lunch option, navigate to the specified folder, there is a TVAP sub-folder, lunch the setup.exe inside that folder.
Aug 09, 2012 | Toshiba Satellite Pro A300 Notebook
When I install the IM software for my SSK webcam it gets close to finish installing but then comes up with the error the following files cannot be found: C:\Program Files\Common Files\Vimisoft...
A few things to try:
Jan 11, 2018 | Computers & Internet
Error code 016 781
The 016-783 error message indicates that “Cause – Could not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the scans in had previously been deleted, so I had recreated the shared network folder. What I had neglected to do though was to recreate the sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup referenced in the job template I had no more error codes with that scanning job template.
Jul 01, 2010 | Xerox WorkCentre M-24 Color Copier
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
When i try to istall audio drivers,im told to specify the folder
Hi
When you start installing the audio drivers, let the folder be the same as specified over there. If no folder location is specified then
specify the folder location as --- C:\Program Files\Realtek
Please do rate this solution as fixya if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Dell Dimension 3000 PC Desktop
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
Konica Minolta Bizhub C224 Color Copier Printer Scanner Logo
980 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
