Question about HEALTHRIDER R60 SoftStrider Treadmill
How to remove motor shroud - HEALTHRIDER R60 SoftStrider Treadmill
Need location and r/r proceedure for fan blower motor on a 2001 grand cherokee limited.
backside of radiator you will see the fan shroud and fan assembly.
4 - 10mm bolts (one on each corner) will be holding it in place.
Remove the bolts (this will take some time as these bolts are in very tight areas) once the bolts are removed, very carefully pull the trans cooler line out of its mounting on the fan shroud (bottom drivers side of the shroud)
Pull fan and shroud out thru the top (be very careful wiggling it out, you do not want to break the shroud)
Once out, remove the fan motor (4 bolts and a round clip holding it in place)
Replace in reverse order.
Hope this helps
Jul 11, 2011 | Jeep Grand Cherokee Cars & Trucks
Is there a fan clutch on a 2000 toyota solara
NOPE YOU HAVE TWO ELECTRIC COOLING FANS. YOU HAVE TO REMOVE FAN SHROUD FROM RADIATOR THEN YOU HAVE TO REMOVE FAN FROM MOTOR USING SOCKET AND WRENCH.HOLD FAN WITH HAND WHILE LOOSEN FAN NUT.AFTER YOU REMOVE FAN BLADE YOU HAVE TO REMOVE THREE SCREWS HOLDING FAN MOTOR TO SHROUD.
Jun 20, 2011 | 2004 Toyota Solara
I need to remove the cooling fan shroud from my 1995 Lincoln Continental. How is the easiest way to go about this?
Engine Fan REMOVAL & INSTALLATION 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the radiator upper sight shield.
  3. Disengage the electrical connector, then remove the integrated relay control/constant control relay module assembly located on the radiator support.
  4. Disconnect the fan electrical connector. Fig. 1: Disengage the fan electrical connector 86873115.jpg
  5. If necessary, remove the air bag crash sensor.
  6. Unbolt the fan/shroud assembly from the radiator and remove. Fig. 2: Unbolt the fan assembly from the radiator 86873116.jpg
    Fig. 3: Remove the fan from the engine 86873117.jpg
    Fig. 4: Slide the fan as an assembly up and away from the radiator. Be careful not to dislodge the mounting stud on the left side. 93143p56.jpg
  7. Remove the retainer and the fan from the motor shaft and unbolt the fan motor from the shroud.
  8. Installation is the reverse of the removal procedures. Tighten the fan shroud retaining bolt to 23–33 inch lbs. (2.6–3.7 Nm). Tighten the fan shroud retaining nut to 71–106 inch lbs. (8–12 Nm). Fig. 5: Constant control relay module location — 3.8L engines 86873118.gif
4.6L Engine
  1. Loosen the fan clutch-mounting shaft from the water pump hub.
  2. Loosen the fan shroud from its radiator mounting and remove the lower hose from the shroud.
  3. Lift the fan and clutch assembly and the fan shroud from the vehicle.
  4. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
    Closely examine the fan for cracks or separation, to avoid the possibility of personal injury or vehicle damage. To install:
  5. Assemble the fan and fan clutch. Tighten the retaining bolts to 15–20 ft. lbs. (20–27 Nm).
  6. Install the fan and clutch assembly and the fan shroud. Mount the fan clutch shaft to the water pump hub and tighten to 37–46 ft. lbs. (50–62 Nm).
  7. Slip the shroud into the lower mounting clips and install the shroud retaining screws. Fig. 6: Fan and fan clutch assembly — 4.6L engine 84173064.jpg
5.0L Engines
  1. Loosen the fan clutch-to-water pump hub retaining bolts.
  2. If necessary, remove the drive belt from the water pump pulley.
  3. Remove the fan shroud upper retaining screws. Lift the shroud to disengage it from the lower retaining clips.
  4. Remove the fan clutch-to-water pump hub bolts and remove the fan and clutch assembly and the fan shroud.
  5. If necessary, remove the fan-to-fan clutch retaining bolts and separate the fan from the fan clutch. CAUTION
  6. Assemble the fan and fan clutch. Tighten the retaining bolts evenly and alternately to 12–18 ft. lbs. (16–24 Nm).
  7. Install the fan and clutch assembly and the fan shroud.
  8. Install the fan clutch-to-water pump hub bolts.
  9. Slip the shroud into the lower mounting clips and install the shroud retaining screws.
  10. If removed, install the water pump drive pulley and adjust the belt tension; refer to Section 1.
  11. Tighten the fan clutch-to-water pump hub bolts evenly and alternately to 15–22 ft. lbs. (20–27 Nm). Recheck the belt tension.
Jul 14, 2010 | 1995 Lincoln Continental
How do I remove the cooling fan shroud from the top of the radiator ? I'm trying to change the cooling fan motor, and I've removed the bolt holding the fan shroud to the radiator, but I can't get the...
I would suggest replacing the cooling fan relay in the fuse compartment under the hood first. Cooling fan motors very, very rarely go bad. You will probably end up having to remove the radiator to remove the shroud. You will save yourself a lot of time and money if you replace the relay first.
Jul 07, 2010 | 1996 Chevrolet Cavalier
How do you replace a radiator in a dodge shadow 1993
These are the instructions for a 4 cylinder motor.
  1. Disconnect the negative (-) battery cable.
CAUTION Do NOT remove the cylinder block or the radiator draincock with the system hot and under pressure because serious burns from coolant can occur.
  1. Drain the cooling system.
  2. Remove the hose clamps and hoses from the radiator. Remove the coolant reserve system tank-to-filler neck tube.
  3. Remove the automatic transaxle hoses, if so equipped.
  4. Remove the fan and fan support assembly by disconnecting the fan motor electrical wiring.
  5. Remove the fan shroud retaining clips, located on the top and bottom of the shroud for most of the vehicles (the Dynasty has them only on the top).
  6. Lift the shroud up and out of the bottom shroud attachment clips separating the shroud from the radiator. Avoid damaging the fan.
  7. Remove the upper radiator mounting screws. Disconnect the engine block heater wire, if so equipped.
  8. Remove the air conditioning condenser attaching screws located at the top front of the radiator, if the vehicle is equipped with air conditioning.
  9. Lift the radiator free of the engine compartment.
Care should be taken to NOT damage the radiator cooling fins or water tubes during removal or installation.
To install:
  1. Slide the radiator down into position behind the radiator support.
  2. Attach the air conditioning condenser to the radiator, if so equipped, with a force of approximately 10 lbs. (44 N) to seat the radiator assembly lower rubber isolators in the mount holes provided.
  3. Tighten the radiator mounting screws to 108 inch lbs. (12 Nm).
  4. Connect the automatic transaxle hoses, if so equipped. Tighten the hose clamps to 35 inch lbs. (4 Nm).
  5. Slide the fan shroud, fan and motor down into the clips on the lower radiator flange. Install new shroud retaining clips.
  6. Install the upper and lower radiator hoses (including the coolant reserve hose).
  7. Plug the fan motor electrical connection and attach the negative (-) battery cable.
  8. Fill the cooling system with coolant (refer to Section 1 for more details).
  9. Operate the engine until it reaches normal operating temperature. Check the cooling system and automatic transaxle (if equipped) for the correct fluid levels. Also check for coolant leaks.
Here are the instruction for a 6 cylinder engine.
6-Cylinder Engines
  2. Remove the hose clamps and hoses from the radiator. Remove the coolant reserve system tank to filler neck tube.
  1. Remove the automatic transaxle hoses, if so equipped.
  2. Remove the fan and fan support assembly by disconnecting the fan motor electrical wiring.
  3. Remove the fan shroud retaining clips, located on the top and bottom of the shroud for most of the vehicles (the New Yorker, Dynasty, Fifth Ave., and Imperial have them only on the top).
  4. Lift the shroud up and out of the bottom shroud attachment clips separating the shroud from the radiator. Avoid damaging the fan.
  5. Remove the upper radiator mounting screws. Disconnect the engine block heater wire, if so equipped.
  6. Remove the air conditioning condenser attaching screws located at the top front of the radiator, if the vehicle is equipped with air conditioning.
  7. Lift the radiator free of the engine compartment.
Care should be taken NOT to damage the radiator cooling fins or water tubes during removal or installation.
To install:
  3. Tighten the radiator mounting screws to 9 ft. lbs. (12 Nm).
  9. Operate the engine until it reaches normal operating temperature. Check the cooling system and automatic transaxle for the correct fluid levels. Also check for coolant leaks.
please let me know if i can assist you in any further problems you may encounter with your vehicle.
please do not forget to rate and comment about your experience with fixya today.
Dec 27, 2009 | 1993 Dodge Shadow
How do you replace radiator fan motor on 1996 VW Vento (Jetta)
You will need to unbolt the 4 bolts holding the fan shroud to the radiator, usually 10mm bolts. Unplug the fan and remove any relays or anything attached to the shroud. Removing the battery may give you a little more room to get the shroud out. Remove the fan from the motor and unbolt the motor from the shroud.
Dec 20, 2009 | 1996 Volkswagen Jetta
Want to replace the radiator on my 1997 ford thunderbird
Radiator Aluminum Core, Crossflow — 3.8L (Base) and 4.6L Engines
Removal
  1. Drain engine cooling system as described. Disconnect upper radiator hose (8260) and lower radiator hose (8286) and radiator overflow hose (8075) from the radiator (8005). Disconnect the transmission oil cooler inlet and outlet lines from the radiator.
  1. Remove cooling fan motor,fan blade (8600) and fan shroud (8146) assembly as described.
  1. Remove radiator upper bracket retaining bolts and remove bracket. Lift radiator from vehicle.
Installation
  1. Position the radiator into the vehicle. Install upper brackets and tighten bolts securely.
  1. Connect the transmission oil cooler lines to the transmission oil cooler fittings.
  1. Install cooling fan motor, fan blade and fan shroud assembly as described.
Engine Cooling Fan Motor, Fan Blade and Fan Shroud Assembly, Electrical Removal
  1. Disconnect (pull apart) the male-female cooling fan motor wiring connector at the side of the fan shroud (8146). Remove the male terminal connector retaining clip from the fan shroud mounting tab.
  1. Remove two fan shroud upper retaining bolts at the radiator tanks.
  1. Lift cooling fan motor/fan blade (8600)/fan shroud assembly past radiator (8005), disengaging fan shroud from two lower retaining clips.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten fan shroud retaining bolts to 5.2-7.2 Nm (46-63 lb-in).
    8d231fe.gif HOPE THIS HELPS.
    Oct 30, 2009 | 1997 Ford Thunderbird LX
    I need to get the radiator fan motor off the shroud
    hello, you say the motor is hinged to the removed shroud ? I haven't seen one in a while but look at the objects. Do they have a little "crater " in the middle on one side? If it does , it is a rivet.
    Take a drill with a thin bit and drill it out from that concave or crater side.
    you will need to replace the rivets with new nuts and bolts. make sure you use a lock washer on the nut side with flat washers to hold the bolt tight. otherwise the vibration from the fan will loosen them quickly after replaced.
    Aug 12, 2017 | 1997 Ford Thunderbird LX
    How do i replace the radiaor? on this 2005 Hyundai do i remove the intake cover, then the cooling fan, the the motor mount? what?
    Below are instructions and a diagram for removing the radiator from your Santa Fe. There's nothing involving the motor mounts. Best of luck and please post back with any questions or just to rate the solution. Greg
    1. Drain the cooling system. Remove the radiator cap to speed draining.
    2. Remove the inlet hose from the radiator.
    3. Remove the transmission oil cooler lines from the retainer clip at the bottom of the cooling fan shroud.
    4. Remove the fan shroud clip from the condenser tubes.
    5. Remove the bolt that connects the fan shroud to the condenser hold down bracket.
    6. Remove the air deflectors from the top of the radiator.
    7. Remove the cooling fan shroud bolts.
    8. Remove the coolant reservoir hose from the radiator overflow neck.
    9. Remove the radiator upper support brackets and bolts that connect to the fan shroud.
    10. Disconnect the engine cooling fan motors electrical connectors.
    11. Remove the cooling fan motors electrical harness from the fan shroud clips.
    12. Remove the cooling fan shroud.
    13. Remove the outlet hose from the radiator.
    14. Disconnect the transaxle oil cooler pipes from the radiator.
    15. Tilt the top of the radiator rearward.
    16. Remove the condenser hold down bracket from the radiator.
    17. Lift the condenser from the mounting tabs on the radiator and position the condenser aside.
    18. Remove the radiator.
    Aug 11, 2009 | 2005 Hyundai Santa Fe
    Need to replace the left rad fan motor, any ideas on how to do it if i have the new part?
    1. Remove radiator from vehicle.
    2. Remove fan shroud retaining bolts, and cooling fan motor/blade/shroud assembly.
    3. Remove fan blade retaining clips and blades.
    4. Remove motor mounting screws and motors.
    5. If necessary, remove Constant Control Relay Module (CCRM).
    6. Reverse procedure to install. Torque CCRM screws to 40-56 in lb, and shroud retaining bolts to 24-48 ft lb.
    May 27, 2009 | 1996 Lincoln Continental
    HEALTHRIDER R60 SoftStrider Treadmill Logo
    19 people viewed this question
    Top HEALTHRIDER Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Electro Med Services...
    Shehu Pro
    Shehu Pro
    Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
