Question about Refrigerators
Good morning, My GE PSS26SGRC SS Arctica profile keeps clicking, and the lights dim when it clicks. The coltrol panel for temp is not working, it just keeps blimking the "24hrs" note. The clicking seems to be coming from behind the unit , and it now as of today is not cooling. Could it be a motherboard gone bad?
aasc
  • 1606 Answers
SOURCE: GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Posted on Sep 16, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE profile side by side model
Yes , the main control board is the problem . Also , make sure the coil roll behind the refrig , is clean . Sounds like the compressor relay on the board itself , is doing the clicking , trying to start a hot compressor , either caused by a compressor cooling fan not working , or the board . If the compressor cooling fan is not working , the board is still probably the problem . I have found , the board clicking , trying to start the fan . Replaced board , and no more problem .
Posted on Sep 25, 2009
Testimonial: "Thank you so much. "
aasc
  • 1606 Answers
SOURCE: GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Posted on Nov 20, 2009
Testimonial: "Thanks for the information on the main control board. I replaced it and its working great. I checked the warranty info but mine wasn't covered."
SOURCE: GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Posted on Sep 07, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a GE Profile Model PSS26SGRC SS and suspect
Sorry to read about your problem, I hope this helps you out.
It around $130.00
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile Model PSS26SGRC SS and suspect it needs a new motherboard. Where can I get one and how much?
It around $130.00
3 Thumbs - Helpful
Dec 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
