Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
How to change the water filter on a frigidar gallery frs26zse
3 Suggested Answers
  • 153 Answers
SOURCE: Icemakers,frigidare, gallery series
read the menual book and try again or replace it.
Posted on Jul 25, 2009
  • 441 Answers
SOURCE: how do I check if defroster heater is bad?
if the defrost heater is gone you will have a large frost build up in the back of the freezer side.
Posted on Jun 11, 2010
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
How do I check if defroster heater is bad? On a Frigidare Side by side Mod FRS26ZSE?
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidare did get water out or make ice
Since both functions are not performing, check your water supply, a clogged filter, a bent supply line, a supply line that is turned off. Internally it could be that every thing is frozen up or your water valve is bad. Joe
Apr 17, 2010 | Refrigerators
How do I clean my oven
Get some easy off oven cleaner. Use gloves. Do not even clean as that tends to melt down expensive controls.
Jan 16, 2010 | Frigidare FED300E Electric Range
Frigidare Gallery 2 speed top loader fills with
It could be multiple problems, if so it's more than one of the below, it would be cheaper to buy a new unit.
Start by removing the front panel and check the belt and idler pulley/tensioner. Look for wear in both and make sure there isn't too much play (it should only move about a 1/2 inch when pushed on it's longest stretch. While you have the front open, inspect the pulley for damage or excessive play.
Another cause could be the transmission (it's just above the pulley). Look for fluid/oil leaks and/or rust. A bad oil leak can cause the transmission to seize up. If you notice rust accumulated on the transmission assembly, you probably have a bad seal. Water could have gotten in there causing it to fail. A damaged transmission needs to be replaced, repair parts are not available.
The cycling problem sounds like a faulty timer. Test it by advancing the dial and make sure the correct cycles are starting/stopping. This part can be replaced with a few simple tools.
As always, make sure you disconnect the power before doing any service.
Aug 02, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Jul 18, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water from the icemaker shoots down the back of the freezer
are you sure the water comming from the icemaker or the defrost drain line clogged
Apr 07, 2009 | Refrigerators
Have a frigidaire gallery frig model plrs267zab8....can't get water, ice maker to work after inserting new filter...
generally the filters I have changed need to be flushed with water before acutally using them because carbon can come out of the filter when first used. I don't know you specific item. Check the direction of the filter it may be installed backwards. Can you remove the filter and verify that you get water flow when the valve behind the filter is on? Just suggestions.
Dec 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
