Question about Garden
How to remove the crankcase from the casing
Stihl 025 fuel tank is cracked and I need to remove the piston and the crankcase from the housing. I've removed all the screws but can't seem to figure out how to remove the crankcase.
    Sergeant:
  • 322 Answers
I assume you have the flywheel and clutch assembly removed and the oil pump moved out of the way?
Posted on Jan 17, 2013
  • Jane Huppert
    Jane Huppert Jan 21, 2013
    Yes, I have removed the flywheel and the clutch assembly along with moving the oil pump our of the way. Now what?
  • Kelly Buxton
    Kelly Buxton Jan 22, 2013
    once all that is removed and the top cover and handle are removed it should just slide out of the case. Carburetor is removed and the boot pushed through the housing as well.
Rope hard to pull on Stihl 025 c chainsaw
If the saw was not running properly last time it was used:
1) What is the spark plug condition, and color
2) If the plug is grey colored:
a) remove the muffler, what is the condition of the side of the piston.
b) are there scratches on the side of the piston
Feb 12, 2017 | Stihl Garden
How do you remove the clutch on a 025?
remove spark plug.
block ther piston with a piston stop.
remove clutch drum exposing the clutch
it has to be turned clockwise to remove it. 19m socket
Sep 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Starts good - idles good - hard to get rpm's
Check for a dirty air filter, clogged spark arrestor in the muffler assembly, or a partially clogged fuel filter in the gas tank.
Oct 30, 2013 | Stihl Chainsaw 42mm Piston Rings 025 O25...
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
Jun 03, 2012 | Stihl Garden
How to remove stihl 023 handle bar?
There are three mounting points. You need to remove the screws behind the plug caps with a T27 bit. Then, the tank should separate from the crankcase and you can pop the AV mount from the crankcase to replace it.
May 24, 2012 | Stihl 021 023 025 Ms210 Ms230 Ms250...
Scorched pistons in a STIHL chainsaw - and its not the fuel mixture
What side of the piston is scored? If it's the exhaust side, it's running too lean, ergo, it's the mix ratio.
Nov 16, 2011 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
