DVD RECIEVER PLAYER HT805 RESET
INSTEAD OF LOADING DISC IT WILL SHOW HOME ON THE START UP
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
  • 3 Answers
SOURCE: TROUBLE WITH KLH DVD-8350 PLAYER
I took the cover off. Moved the lense to the outer edge with my finger. Then rubbed the lense with a q-tip soaked in eye drop fluid (rubbing alcohol would work better). Then wiped it with the dry end. Works greats now!
Posted on Jan 04, 2009
mnelsonix
  • 58 Answers
SOURCE: dvd player reads no disc and than shows loading
Have you tried other DVD's...you might have a bad one.
If so,,,you may need to clean the laser diode. You'll need cottonless swabs (no lint swabs) and Isopropyl alcohol 99%.
Might be hard to get to, depending on the model, but gently swab the diode lens. Don't saturate it tho.
good luck
Posted on Apr 07, 2009
  • 35 Answers
SOURCE: Coby TF-DVD7100 (portable dvd player) says "no disc"
when it says wrong disc, optical pickup assy needs to be replaced J.D.W.
Posted on Jul 12, 2009
Only shows loading on face of player
either some how the remote has become unsinked or the reciever is bad in it
May 22, 2012 | Kenwood DV-605 Multi-disc DVD Player
I can get the home page up on the tv where it says cyberhome. i put disc in and it says loading and then it says bad disc. what does a bad disc mean?
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Apr 16, 2011 | Cyberhome CH-DVD 300 DVD Player
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
Disc loads, but won't play
Are these factory DVD's? Or burned ones? Als, are you loading te disc correctly. I have a PowerAcoustic and the DVD MUST be loadedupside down.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Boss DVD-7500 Car DVD Player
I put a disc in but the DVD player continues to stay Loading. It won't show any picture on the tv screen and when you try to select a DVD # it continues to say Loading and shows HD480.
Sounds like the optical drive on your Samsug has gone bad, or is dirty. Have you tried any DVD cleaners. Circuit City and Best Buy carry good ones for under 20bucks. If the cleaning doesn't work then I suggest having the unit serviced.
Jan 10, 2009 | Samsung HT-X50 System
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Jan 19, 2008 | TruTech PVS2119 19 in. LCD Television
SAYS NO DISC
Try playing commercial DVD instead of DVD+R or DVD-R.
Mar 06, 2007 | Audiovox AVD300T Car DVD Player
 Grubhead
Grubhead
