Question about Magellan RoadMate 1220 GPS Receiver
How do I get a new T300-3 battery for a magellan 1220?
Battery rating = 3.7v 720mAh 2.66Wh
Where can I purchase battery for fx730 portable DVD player
Unfortunately you can not buy a new battery since it is not sold by Sony. It is possible to patch a similar cell into your existing battery. Be warned that it would be difficult to do this.
Link to Cells: http://www.batteryspace.com/polymer-li-ion-cell-3-7v-2500-mah-544792-2c-9-25wh-5a-rate---un38-3-passed.aspx
Guide to removing battery: http://www.ifixit.com/Guide/Sony+DVP-FX730+Battery+Replacement/7812 (There is a comment on this page that lead to the first link)
May 20, 2014 | Sony DVP-FX730 Portable DVD Player
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
I need an instruction manual for a magellan sn 0786100317612
You should be able to find the manual you are looking for here:
http://www.retrevo.com/support/Magellan-1220-GPS-manual/id/23341bh638/t/2/
Hope that his helps... don't forget to rate me! :D
Oct 15, 2010 | GPS
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
When i turn on my magellan 1220 the screen freezes at the logon screen and does nothing. is there a way to reset the system?
I'm also having the same problem with the same model. But there is no reset button with this model. Even the manual says nothing about a reset button. Help!!!
Apr 30, 2010 | Magellan RoadMate 1220 GPS Receiver
It want turn on a
Battery is bad, try connecting to the car to see if it comes on.
Nov 16, 2009 | Magellan RoadMate 1220 GPS Receiver
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Satellite contact
make sure your battery ois fully charged, or nget new batteries of a stronger rating
Jun 28, 2009 | Magellan RoadMate 800 GPS Receiver
Magellan RoadMate 1220 GPS Receiver Logo
52 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
