Question about Norelco Irons
Norelco Easy Steam 503 Iron manual - Norelco Irons
2 Suggested Answers
  • 8 Answers
SOURCE: gunk coming out of iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.
Posted on Mar 30, 2009
How do I put water in the Sunbeam Steam Iron #GCSBBV-200
If the GCSBBV-200 is similar to other Sunbeam steam irons, fill the iron when it is cool and unplugged. With the ironing surface flat on the sole plate, set the Steam dial to dry and the Fabric Select dial to Min. Then use an easy-pour measuring cup to pour water into the opening at the top front of the iron. Make sure not to fill past the maximum fill level. (Tip the iron up as if you were resting it between passes with the iron to check the level.)
I hope this helps.
(Sunbeam has the manual for the GCSBBC-395 on their support site: http://www.sunbeam.com/service-and-support/product-support/instruction-manuals/garment-care/other/garment-care-other-manual.html . The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-sunbeam-Site/Sites-sunbeam-Library/default/v1425126445413/documents/instruction-manuals/160253.PDF . Check how similar your iron is to the newer models.)
Mar 01, 2015 | Sunbeam Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
My Norelco steam iron 1513 B, lights up, but does not get hot.
It likely has a burned-out heating element. Probably time for a new iron.
Jul 26, 2009 | Irons
Gunk coming out of iron
Mar 29, 2009 | Irons
Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
Jun 10, 2008 | Irons
Irons Logo
600 people viewed this question
Top Norelco Irons Experts
Are you a Norelco Iron Expert? Answer questions, earn points and help others
