I cant get both channels on at the same time on my receiver i side stays muted and i have both lav mics on
SOURCE: Only receive 2 channels.
Can you punch in the channel numbers directly to go to the channels, but just not tune to them with the Channel Up/Down buttons?
If so then try tapping the favorite button on the remote until the screen shows "favorite mode off". This mode likes to stay [or perhaps turn] on when you scan for channels, but scanning clears everything in the favorite list except for the channel you are on when you start the scan (so it seems), thus leaving only one or two channels showing up. (This happens whenever I re-scan for digitals.)
To pick out favorite channels, go into the channel menu in the tv menu and with "Favorite: Analog" or "Digital" highlighted near the top, hit OK on the remote to toggle favorite status.
SOURCE: tobshiba tv stays in one channel.
You might need to go into the menu options and set the input from cable to air or vice a verse. The tv in my kids room is like that if it's set to cable with no input at the cable jack then it only gets one channel even after you try to add channels.
SOURCE: Olevia 537 - wont select HD channels
I assume the control panel on the tv still works correctly?
If so i would think you have a remote problem.
If thats the case let me know I will send you a link to instructions to repair your remote.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: how do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
SOURCE: ECM55b lav mic cable problem/question
There should be just one center conductor and a shield. It's tricky but, these can be spliced. Some just have two conductors, no shield -- this is easier to splice.
