Question about Samsung SGH-F250 Cell Phone
I am not getting any sound - Samsung SGH-F250 Cell Phone
HOW DO I GET SOUND WITHOUT USING REALTEK ON A INSPIRON530?'
Realtek is the name of the sound card in the laptop. You need to have realtek audio drivers installed to get sound. Sort of difficult to change out a sound card on a laptop- in fact mostly impossible.
get the Realtek driver and live with it.
Sep 15, 2014 | Computers & Internet
I can not get sound on my computor
Turn your speakers on. Turn the volume up in windows.
Oct 30, 2012 | Computers & Internet
My thosiba equirum aptop sound not working where caN I GET CHEAP
You can easily get an external USB sound card from any local Computer shop for around $ 10
Jul 16, 2010 | Toshiba (4CH-VOUT) Sound Card
Cant get sound
see your m powerd out put.
Apr 04, 2010 | M-Audio Delta 1010 LT Sound Card
Toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
easyab
ConvergenceRepair.com
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
No sound
obtain latest sound driver for your sound card or machine, go into device manager remove sound device driver,reboot,when it says found new device ,sellect have disk ,then sellect where you have saved the new driver,then follow the onscreen directions
this should get your sound working ,if it is a hardware problem install a new sound card,(if the sound is onboard ie (part of the motherboard), be sure to disable it before you try to install the new sound card)
good luck
Terry
Mar 01, 2008 | Systemax (988970) PC Desktop
Altec lansing acs54 installation
Hello there!! jlee432
The 4.1 speakers you has, and output sound , depend on the sound card you has on your laptop. If you has inside the laptop a sound card 5.1 you whould not have problems get it sound, BUT you have to set on multimedia and sound for 4.1 according.
you only have one output sound on your laptop, so you have to use 2 speakers or buy a splitter and get 2 speakers sound.
you also, can buy a pcmcia sound card, 5.1 from creative labs, to solve this. but check if your speakers of course sound of.
good luck
Nov 29, 2007 | Altec Lansing ACS 56 Computer Speakers
Samsung SGH-F250 Cell Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
