Question about Technics SL-1210 Turntable
Technics 1210 Stroble Flicker and Low torque
I just replaced Q1, Q2 and D3 to solve my previous problem (after shorting out the target lamp). I now however have the problem of low torque. The platter spins up slower than my other deck (about 1/4 of a rotation slower) and then takes less pressure on the platter to stop. When the platter is stopped (under pressure ) the red strobe light seems to flicker? any suggestions what this may be - could it be one of the IC's or just a brake adjustment needed? thanks
2 Suggested Answers
  • 6 Answers
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
Technics 1210 mk2
As everything was normal before you started the work, I'm thinking you might have disturbed something. Such as caused a wiring plug to come loose. Maybe even a bad solder joint somewhere?
Apr 28, 2014 | Audio Players & Recorders
Technics sl-d3 will not start up
You need to move the tone arm across to the record for it to start. Cheers john
Oct 05, 2013 | Technics SL-1210 Turntable
There is power going through my technics 1210,but the platter & strobe light still will not work
how do you know theres power to the unit if theirs no strobe light pitch adjuster light & the platter doesn't spin?
the power comes in & to the transformer first,then through the strobe switch, the transformer is what blows when you short the target light out.....i've seen this many a time when people try & change the target lights to blue neon.
Mar 04, 2013 | Technics SL-1210 Turntable
Has anyone else had the problem with their 1200 technics,where the turntable doesnt spin,it judders back and forth??
1, The regulator circuit has failed, usually transistors Q2, Q3 and zener diode D3.
OR
2, The drive I.C (I.C101 / AN6675) has failed, this can be natural failure but also can happen if the deck is turned on and started with the platter removed.
Free Technics SL1200 / SL1210 service manual available here :-
http://www.technicsdjuk.com/
http://stores.ebay.co.uk/methleykev
Dec 27, 2009 | Technics SL-1200 Turntable
I have a sportsart 6300 that keeps blowing up Q2 and Q3
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Jul 12, 2009 | Sportsart 6300 Treadmill
After mixing for a while the turntable (1200 technics mk5) starts to lose the pitch or the record starts jerking up near the -5 or -6.
hi! there is a problem inside your turntable (on the main board) check the components  TRANSISTOR    Q2, Q3,  ZENER DIODE   D3..
CHANGE IT IF POSSIBLE..
Jun 14, 2009 | Technics SL-1200MK5 Turntable
Amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Apr 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Target light won't turn off
Your wires are crossed. You'll have to switch them out. Make sure when you put the wires back together, that they are covered properly with either electrical tape, or heat shrink tube. If any part of the wire is exposed and it touches the cabinet, it will ground/short out your turntable, and you'll have an even bigger and more expensive issue to fix.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 30, 2009 | Technics SL-1210 Turntable
Lamp replacement fears
No flying screws on the lamp (on this model anyway) you should have no problems!
Feb 13, 2009 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
102 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
