Question about Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MS2331/17
The set will not stay on
  • netaware Jan 24, 2009
    32MT3305 stays on for 5 to 10 minutes then shuts off
  • 88 Answers
Hi. you need to check power supply unit of high voltage capicitor. if under reading replace it. goodluck!
Posted on May 24, 2009
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
No remote have universal remote what are codes for magnavox sdtv
Hello
You haven't specified details about your Magnavox. There is Philips Magnavox and Magnavox. Anyway I'll give you codes for both Philips magnavox and Magnavox.
MAGNAVOX CODES
Three digit universal remote codes are
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
Four digit universal remote codes are
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
PHILIPS MAGNAVOX
Three digit codes are
183/ 184/ 208/ 213
Four digit codes are
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 03, 2011 | Televison & Video
I have lost the manual for my Crest model Po5094-2 remote. I need the code for Philips model 29PT468A TV. Can you please help?
Hello
four digit remote codes for Philips are:-
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Four digit remote code for Magnavox are:-
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Three digit remote codes for Philips are:-
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Three digit remote codes for Magnavox are:-
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
NB: Switch OFF and switch On the tv with its front panel power switch each time before gointg to an other code.
Direct Code Entry
Ok
Jan 15, 2011 | Philips Universal PH301S Remote Control
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I cannot get closed captioning to turn off and stay off on my magnavox tv. the menu has no cc options at all. and the remote turning it off is onl,y temporary. any ideas?
I have the same problem, but I cant even get a code for my universal remote to access my menu or any of the settings. Dont think I will buy Philips/magnavox any more.
Oct 19, 2009 | Philips Magnavox 20MS233S 20" TV
TV turns itself off
I currently work in teir 2 support for magnavox philips and this is a service issue i see alot on random sets hope this helps sorry fotr the bad news.. David
feel free to e-mail me with any other questions at davidsylvia411@hotmail.com thanks.
Nov 19, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Philips Magnavox 27MS343S 27" TV Logo
248 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
