I need a basic step by step set of instructions on how to use an office printer including fax and scanner nothing with too much detail like everything i have found can anybody help????
  • Gary
    Gary May 11, 2010
    What is the make and model you need instructions on?
  • 62 Answers
Go online and look under manufacturers website where you should be able to download a user maual for free as long as the printer is not real old.
Posted on Feb 14, 2009
How do I pre-send phone numbers
Perform following steps on your fax machine.
Press set up (wrench shaped icon) button of printer >> Basic Fax Setup >> Fax Header >> Your Fax Number. Here please enter your fax number then press OK.
Mar 02, 2016 | HP Office Jet 4500 Wireless All-in-one...
Steps to install c350 and the drivers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Jul 08, 2015 | Konica Minolta Bizhub C350 Digital Copier,...
How can your fax machine on your canon pixma mx397 work? steps please.. thanks!
For details check Canon Pixma Mx397 Manual. Turn on your your printer. Press "FAX" button from printer. Load the document you want to fax on platen glass. Customize scan contrast and resolution settings as you need. Use numeric numbers to dial receiver telephone number. Start sending. You document will be faxed successfully.
Aug 03, 2013 | Office Equipment & Supplies
I have a Lexmark P6250 I was told it was an all in one..but I can not see where to hook the telephone cable to fax.
The Lexmark P6250 is an "all-in-one" Printer/Scanner/Copier, but does not include hard-line fax capability.
Unfortunately, there came a time when the manufacturers began referring to any printer/scanner/copier as an "all-in-one" whether it included direct faxing or not. Many of them do not, which makes for a very confusing purchase!
The user's guide (which can be found at www.lexmark.com) gives a basic overview of how to fax using their included software, but in order to do so, you will need to have a dial-up fax modem in your computer, or some kind of internet fax service.
Hope this is helpful!
May 18, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Set UP of HP Photosmart C7280 All-in-One Fax Printer Scanner Copi
The cd that came with the printer did you install it?
Usually when it shows 1 through 5 it means that you need to complete 5 steps for that to work.
Dec 24, 2008 | HP Office Equipment & Supplies
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
HP officeJet K series scanner failure power off and on again
Hi.
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with the scanner hardware
Please follow the below given instructions to resolve the issue.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Hope, this solution would work for you.
Regards,
Lawrence
Jan 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
jasbo
jasbo
