Question about Vocopro CDG-4000 CD Player
Bang and olufsen cdx
Hi i have a bang and olufsen cd x using the best transport ever made the cdm1 its showing a question mark in the display sometimes it plays then it wont any ideas thankyou
0 characters
1 Points
CDX keeps ejecting CDs some seconds after insertion
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Oct 08, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Dead Arcam CD73
Hi 2002tii
These are a cool old machine. They use the cdm1 laser mechanism that was revered in its day for high performance. If you have voltage available after the rectifier stages, check the 3 pin voltage regulators. Marked as 78xx for positive regulator, and 79xx for negative. the xx gives you the voltage they are supposed to be putting out. They commonly fail, also check the same for dry solder joint. resolder them anyway if you are unsure. If all the regulators check out, then also check low value flame proof resistors in the power supply rails. Get back to me here again and let me know how you got on. Good Luck
Aug 07, 2008 | CD Players
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Sounds like the operating system has crashed somewhat.... Is it still operational enough to read a firmware update disc?
Jan 12, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Does it pop out immediately? If not, listen carefully to the drive after you insert the disc. Can you hear the disc spinning? Any activity from the laser? If the disc is not spinning but you can hear the faint whirring and clicking of the laser transport, it could be that the laser itself has failed - it's the laser that detects if a CD is present. If it doesn't detect anything (due to being knackered!), the disc will not spin and will eject.
Oct 31, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
CDPops Out
There are many users with the same problem. I have it also with one of my cdx. Dr see d'EX at youtube; shows a modification to solve this problem. He makes a kind of cushion with a ducktape and tries to fix a cable at the back of the player. Anyway, i've tried it and it worked ... for a while. Know the problem consists, and I will take my Unit to a service point. It is a shame that there is no sufficient information on the net regarding this problem. Many cdx owners have this problem. Numark says the lens needs to be replaced. to be continued.
Oct 15, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
Vocopro CDG-4000 CD Player Logo
321 people viewed this question
Top Vocopro CD Players Experts
Dave Jukebox
Are you a Vocopro CD Player Expert? Answer questions, earn points and help others
