Question about Craig Cma3500e 2 Gb Digital Media Player W Portable Speakers Comp. W Ipod Iphone
I have a CMA3500E. How do I install the CD program?
How can i turn on my Craig cma3500e it's first gets on hold and than say bye bye
Go to apps it will come up with the games you want(then you press install the game you choose)
Feb 24, 2015 | Craig Audio Players & Recorders
Can't install program
If it starts to install and then crashes try running the install program in Compatibility mode with a previous version of Windows. Most of the time when I run into this it is a compatibility issue. If your CD drive is not reading teh disk then the problem is the CD drive or CD itself.
Dec 03, 2011 | Vivendi Mastercook Cooking Light 4.0 Full...
Can not find the program download for a mac. the product came with a mini disc that I could not use to install the program onto my macbook pro. How do I install the program. And once installed, now do I...
Not sure what program you are reffering to but you could find someone with a portable CD-drive with a tray to load up the disk or get somone to burn the program onto a normal CD-ROM.
Chances are, however, that the program is meant for windows as it came on a mini-CD....
Jun 30, 2011 | Computers & Internet
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
I'm trying to install CD Label Maker (Data Becker)and can't install to windows 7 (64 bit). Is there an upgrade availabe? Installation CD is for Windows 95/98
Often old programs will install if you go to the CD and make install.exe or start.exe "run as administrator".
Some times you also then have to run the program, after it is installed, in compatibility mode. Again, right click on the program icon, select the compatibility tab, select an old OS like XP or what ever the program used to run in.
Aug 22, 2010 | Computers & Internet
How can i install the powerpoint 2003?
  1. Insert the installation CD in your computer's disk drive and allow the installation to automatically begin. If the install doesn't begin automatically, click on the "Start" button at the bottom left-hand corner of your PC and choose "Control Panel." Next choose "Add/Remove Programs." Next you will see the option to install from a CD or floppy.
  2. Step 2 Choose the "CD or Floppy" option. Windowsmag-glass_10x10.gif will locate the previously inserted CD and begin the installation. You will be asked to enter your end user license agreement. Enter your license number that is located on the box of the software you purchased. Click "Next."
  3. Step 3 Choose the location you want to install the program. For example, the name of your local disk and the "Programs" folder will be displayed. If you do not want to install in this area, click "Browse" and go to the location on your PC you want to install the program. Once you have chosen the location, choose "Next."
  4. Step 4 Click "Install" on the "Begin Installation" page and the installation process will begin. This process might take a few minutes to complete. Once the installation has completed, you will receive a message the installation has completed successfully. Click "OK," "Next," then "Finish."
  5. Step 5 Verify the program has been installed successfully. Click on the "Start" button, then "Control Panel." The programs that are installed on your computer will be listed. Verify the PowerPoint 2003 program is listed.
Aug 02, 2009 | Microsoft Office PowerPoint Home and...
HP Scanjet G3010 RE-INSTALL PROBLEM (WIN/XP)
hi hots2,
i ve been solving ur problem through live chat... when my power got cut.... pls respond to my omments to the chat.... u can go to ur "my profile" page and clik on the chat.... the entire transcript will be available.... though we might not be able to chat... we might still respond through comments...
thank you
May 04, 2009 | HP Scanjet G3010 Flatbed Scanner
I am unable to install Samsung Studio
Hi
Go to samsung site download the software and install .
Jyo
Jun 19, 2008 | Computers & Internet
INSTALLING PICTUREPROJECT
Most all software can be installed from the cd and by running the setup program in the correct folder on the cd. If the cd/dvd is set to autoplay, then the setup program will load after inserting the cd in the cd/dvd drive.
You may not necessarially have to have the camera plugged in to install the program/s.
May 26, 2008 | Nikon COOLPIX L3 Digital Camera
Printer program
i think driver u have installed is not support cd label print. u go to your vender who provide u printer. or u have better option to upgrade your driver which support cd label print. good luck purushotam
Sep 18, 2007 | Office Equipment & Supplies
Craig Cma3500e 2 Gb Digital Media Player W Portable Speakers Comp. W Ipod Iphone Logo
20 people viewed this question
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
