Question about IEI IMBAQ670 ATX motherboard supports 32nm LGA1155 Intel Core i7i5i3 CPU per Intel Q67
Common Issues with IEI IMBAQ670 ATX
Cannot boot usb pen drive
2 Suggested Answers
SOURCE: I have a iei nano-pvd525-R10
Hi vwatts,
I beilieve you will need to use a different power supply that has all the power cable needed for your board.
for the power pins there should be a 20 pin power connector and another 4pin power cable that makes it 24 pins and another 4pin power cable for the Processor power.
if our power supply does not have that the you really need a new power supply.
correct me if I am wrong.
Have a nice day,
mvincentc
Posted on May 15, 2011
How to boot windows xp from pen drive
http://techgage.com/article/creating-bootable-windows-xp-7-8-flash-drive-installers/
Aug 24, 2014 | Microsoft Windows XP Professional
Tip
Windows 7,Linux and other OS install from USB Pen drive, Flash Drive
To Install Windows 7 via USB Flash Drive (Pen Drive)
You need:
USB Flash Drive (Pen Drive) minimum 4 gb for windows 7
Windows 7 ISO image file.
UNetbootin software download from here UNetbootin
Download the Unetbootin software, and open the file and click "RUN".
below window will pop
You can aslo install other OS's like linux etc etc. for Windows 7, click "Diskimage" radio button, locate or browse the ISO file of your OS by clicking "..." button.
select Drive: (in my PC usb drive is "I:" and press OK.
Next window looks like below picture
Wait till Installation Compleate.
after compleation. Click "reboot" to install to the same PC, or remove the Flash drive(Pen drive) and plug it to another PC or Laptop USB
and boot that System by USB Flash drive.
To do this Select the USB boot option from the BIOS. Or to boot from USB go through your Motherboard User Manual.
This method works on most of Machines with USB booting option.
I personally installed 100's of PC's via this method
thank you. Keep smiling. aaarwind
for other OS setup's via USB drive refer to below Website:
UNetbootin - Homepage
on Jan 20, 2011 | Computers & Internet
Can't boot from USB on motherboard "ASUS p5s-mx se". No issue on BIOS Setup menu !
Start and pres Del /F 2 /F10 for Setup bios .Change the boot sequence.
Usb drive 1st
Hard disk 2nd
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Phoenix BIOS setup and help
And make a boot-able pen drive.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it helps.
Jan 19, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
BIOS settings to boot from pen drive
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Apr 03, 2010 | Computers & Internet
For bootable pen drive
first of all:
the computer u want to boot with the usb-pen drive has to support booting from usb (BIOS setting)
use program drivekey by hp to make usb-stick bootable(format to FAT or FAT32
get usbdos + components or linux as operating system on stick, u cannot install windows on a stick!
good luck, many have tried, only pros worked out how...
Jun 12, 2009 | Microsoft Windows XP Professional With...
How to make bootable pen drive
A FEW THINGS BEFORE YOU DO THIS....
1. Your Laptop has to support booting from a PEN DRIVE. Some BIOS's may refer to your pen drive as a USB floppy or USB zip.
2. The USB flash(pen) drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. Below is a utility from HP that you can use to make your pen drive bootable.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=MTX-UNITY-I23839&jumpid=reg_R1002_USEN
Mar 26, 2009 | Computers & Internet
Hi, I have a computer into which I want to boot without the Hard Drive using a Pen Drive. I tried PortableApps application installed in my 8 GB Flash Drive and unable to boot with it. The Operating System...
Your pen drive needs a boot sector and an operating system.
1.) Format the Pen Drive using HP format tool found HERE. It's a 2 MB download. There is also a link to Windows98 system files. You need those if you want to boot your computer in MS DOS from your pen drive. The above method will not let you read/write to NTFS drives.
2.) If you want to boot a semi-functional windows from your pendrive you need "BART's PE Builder" found HERE, and a windows instalation CD (the list of supported Windows versions is found on the same site). "Barts pebuilder" is designed to create bootable live windows CD-s for system administrators and "geeks", there is a small .BAT file in it that installs it on your pen drive. Read a few readme files and follow the instructions on the web site.
3.) If you want to boot Linux from your pen drive visit this web site http://www.pendrivelinux.com/
Mar 08, 2009 | Computers & Internet
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : safiqul.alam@gmail.com
Mar 25, 2008 | Electronics - Others
Problem regarding usb booting
the hard drive registered in the standard cmos utility is the only one that could be registered for boot in advanced cmos setup and no other, if your usb hard drive and pen drive could be registered in the advanced cmos setup - where boot options are registered, surely it will boot your pc.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 16, 2008 | Asrock P4I45GV R5 Motherboard
IEI IMBAQ670 ATX motherboard supports 32nm LGA1155 Intel Core i7i5i3 CPU per Intel Q67 Logo
Top IEI Computers & Internet Experts
David Payne
David Payne
Are you an IEI Computer and Internet Expert? Answer questions, earn points and help others
