Question about Refrigerators
GE Refrigerator GSS25XSRDSS water tank frozen and cracked again.
We have a GE Model GSS25XSRDSS Refrigerator. Since we got it new the water tank has frozen two times so we changed it. Then we started to have problems with frost and also when it defrosted the ice in the ice bin would melt and make a mess like a frozen water fall in the freezer. So we changed the Defrost Thermostat, the Thermistor near the defrost thermostat and the Defrost Heater Assembly. When it defrosted the ice in the ice bin started to melt again and to drip from the bin and when it started to cool again and the water tank frozen again and it is cracked again for the third time and needs to be replaced. What can be the problems this time.
3 Suggested Answers
mreid542
  • 166 Answers
SOURCE: My ge side-by-side refrigerator/freezer isn't
Yes that is right. Turn the Refrigerator off/ unplug it. Remove the rear panel of the freezer and thaw out the coils with a fan or hair dryer.
The most common problem is with the defrost heater. Using an ohm meter check the heater for continuity but unplug the 2 wires (one from each side). This should be a glass encased heater. you can also very gently pull both ends of the heater and if it is bad it will come apart instead of feeling "springy". If you have only one heater your new replacement will probably be a 2 heater kit.
I
Posted on Jun 16, 2010
jmgldsmth
  • 2005 Answers
SOURCE: The freezer side of my built-in side by side
the defrost thermistor is your problem: it is going low (turning off) the defrost circuit far too quickly; it is a solid state version of a gas filled cold control sensor.
It "tells" the adaptive defrost controller circuit board the condition: (frost level) of the evaporator and, intitiates the defrost mullion heater timer. if it turns off to soon defrost
mullion heaters turn off and, icing occurs. I do not know; right off hand: which boards you are alluding to; however I believe you are referring to the power supply board for the
Posted on Jul 20, 2010
Testimonial: "I will let you know after replacing the part if it fixed the problem. I tested the thermister at 32F and it shows no continuity(infinity). Many thanks"
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 04, 2012 | Refrigerators
FREEZER AND REFRIGERATOR NO LONGER COOLING (GE MODEL GSS25XSRDSS)
Not enough info. If the unit is totally dead then I would suspect the main board (in the rear under a panel) if the fans are running I would suspect the compressor is not running.
Oct 16, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Water on door is not working
I assume the icemaker is working.
If you can hear the water valve in the back of the ref. when you activate the water dispenser and get no water I suspect the water tank has frozen.
The water tank is located behind the crisper dwares in the ref. section.
If tank is frozen it may be due to incorrect temp setting in ref. To cold causing tank to freeze.
If tank is not frozen the water supply line in the door may be frozen due a void in the insulation in the freezer door.
Jan 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE GSS25VGMWW side by side refrigerator
1st remove the line to the despenser at the valve and hold a cup under the valve and have someone try to dispense water, if water comes through the valve then it is good and getting power. if this is the case remove the toe kick at the bottom of the unit and find the 5/16 water connector at bottom left. disconnect it and call for water again, if it does not come out here your line or tank is frozen. if it does come out here it is frozen in the door and ge makes a kit for this which is easily insatalled if directions are followed
Jan 08, 2009 | GE GSS25VGMWW / GSS25VGMCC Side by Side...
Need install instructions to replace water tank
there is no online instructions that i am aware of.
Jun 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
