Question about Dell Inspiron One 2330 io2330-6580BK All-in-One Desktop PC with Intel
Display settings tried to connect to tv and switched display settings and set only on 2nd display and now i am unable to see anything
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Posted on Jan 11, 2013
I've connected by Dell Latitude D620 VGA to my HDMI LCD TV but there nothing displaying on the TV
Try lowering screen resolution on TV. There is a chance your video card can't handle HD like 1080 dpi or higher. Plus make sure TV input is set to VGA.
Aug 31, 2012 | Dell Latitude D620 (D620-rfb1.6) PC...
I have a 42" samsung plasma Model PS-42C91HD. When I connect my laptop to TV I am unable to get a picture. I think I have the right connections. What mode do I watch it in (ie AV1 etc..) or watch setting...
First tell me, how did you connect the laptop to the television what connection did you use? did you use VGA or Svideo?
Heres a video on how to enable the 2nd monitor or svideo to get picture to the tv, ones you have set it to the right channel. Depends on what you connected it to?
http://www.svideo.com/displayvideo.html
Mar 25, 2009 | Televison & Video
My playstation 3 was working fine, im now trying it on another tv and it wont work. i have tried all the reseting display settings by putting the console on standby and holding down the power button until...
Please check the cables used to connect the ps3 to the tv screen. whether it has been copatible or may experience constraints to connect. Replace immediately if the cable is not good. ps3 section for setting the output to a tv. hopefully help.
Aug 02, 2011 | Sony Playstation 3 (PS3) Console
HDTV won't diplay/detect input from my Acer Laptop
A u sure u have extended windows desktop or put it in to clone mode. maybe u haven't selected proper source on TV. just try with something besides TV maybe cable is too long or not working.
Aug 29, 2009 | Acer Computers & Internet
I am trying to hook up my HP Laptop to my 47'' Insignia HDTV. When I plug in the display, my laptop displays only my desktop background and the tv says ''Mode Not Supported''. I am unable to even change...
try changing your resolution for your laptop before you plug in your TV, the screen refresh rate of your monitor,(click the following, control panel, personalization, display settings, advanced, monitor Tab). Also what make/model video adaptor are you using, try updating the drivers, if this helps, please give a fixya rating. Thanks
Jul 10, 2009 | Televison & Video
Acer aspire 4315 connect to TV problem
you should be able to right click on an empty space on your desktop and choose graphics properties and then the output option should be able to be set and the resolution changed if needed, set your tv for AV3 or s video and connect a seperate audio cable as s video is video only
Sep 10, 2008 | Acer Aspire 5050-3242 Notebook
Nokia N70
Go to Setting-Network-Operator Selection. Keep it Automatic
Go to Setting-Call-Send my caller ID. Keep it Set by network
& check your line in use. Keep it in Line 1
Jul 06, 2008 | Nokia N70 Cellular Phone
Acer notebook VGA problem
Not sure about your model as the header is Dell D600 and you mention Acer but the solution is probably the same. You need to enable the 2nd display - I'm assuming you are running XP. Go to display settings -easiest way is to Right click on the desktop, bringing the display menu and Left click on Properties (bottom entry). Then click on Settings and you should see 2 screens and you will need to enable the 2nd monitor and set up how to display on it. Additionally there is a setting in the BIOS that enables both display outputs.
Feb 19, 2008 | Dell Latitude D600 Notebook
Nokia N70
check your settings, try to OFF th Fixed Dialling. Go to the SETTINGS then SECURITY to PHONE and SIM then FIXED DIALLING. If it does'nt work try reformat your fon but the worst thing your file saved on your fon memory will be deleted.
Jul 05, 2007 | Nokia N70 Cellular Phone
Dell Inspiron One 2330 io2330-6580BK All-in-One Desktop PC with Intel Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
