Broken Termostat I' ve problem with temperature,is to high.If I seting up 30,40 usually going up to 60 mayby evan more. Where I can buy termostat??
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Oven temperature remains on high only
It seems a termostat problem.
Oct 27, 2014 | Kitchen Ranges
I NEED HELP BADLY ON MY 2001 CHEVY BLAZER!!!!
Check coolant inside the radiator add if nesesery
start engine for 10 minuts or let the gauge temperature in the midel
stop the engine and touch the lower radiator hose if it is not hot renew the termostat .if hot termostat is good
restart the engine and check if electiric fan run when engine about 200 Fahrenheit
let me know for more help
Jul 16, 2014 | Cars & Trucks
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
I changed a coolant and the termostat on my 1996 toyota T100,but when running the temperature gauge goes high;what can i do to fix this problem?
were you having an overheat issue before changing coolant and t-stat? if not check your t-stat to make sure it is not upside down
Nov 28, 2010 | 1996 Toyota T100
How ican fix the high temprature problem
Water level, good thermostat, good water pump, fan working? All things to check.
Sometimes an airlock will prevent water circulation
ALSO verify your temp gauge and sensor is working correctely. A failure of these may appear as high temp and even shut machine down if the sensor is bad.
Apr 26, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
2000 Buick LeSabre No heat, blows cold air.
check to see if both hoses are hot going to your heater core if they are then core is fine.That would point to your temperature sensor.
Feb 07, 2010 | 2000 Buick LeSabre
I have a 1996 volkswagon jetta and I removed the thermostat but the temperature guage is still going pass half. Is there anyway to get the air out of the system and solve this overheating problem?
hallo
without termostat, start the car. in one minute ideling, both hoses from cooller should be warm.
If only top one is warm, check if the hose from front wather cooller to expansion tank is blocked (small one on top). usualy it is blocked on wather cooller itself .if OK, change wather pump.
also check if presure is bildinh inside wather sistem. that indicate head gasket or head itself should be checked
If you had remove the termostat, there can be no air inside the engine (if wather is inside).Even with termostat present, VW has no problem with air pockets.If your temp.go pass half when car is standing still, that is ok, but when driving must drop down.
Marko
Sep 23, 2009 | 1996 Volkswagen Jetta
Saecco Taleo Touch Espresso Machine
Make sure you preheat the cups, as that can make the world of diffrence.
if that dont help send it in to a offical Saeco repair station for upgrading of the software, or change of termostat or boiler.
May 27, 2008 | Saeco Coffee Makers & Espresso Machines
Washing Machines Logo
Top Washing Machines Experts
