Question about HP 564 XL Series Ink Cartridge Set for B8500 C309 D5400 -5 Pack
I've bought new cartridges and it keeps telling me cartridge problem or cartridge appear to be missing; What can I do about this problem ? or do I have to return the machine to you for a refund or
I've tried everything cleaned the heads of the cartridge and i changed the cartridge it's still frozen, What can I do?
  • 110 Answers
Please install one cartridge at a time and close the cartridge access door to check if the error pops up.
Also inspect the T shape vent on all of the cartridges, which should be clear and not clogged.
While installing the cartridges, make sure there is click sound when you install it.
If issue still persists, contact HP Tech Support as it could either be an issue with the Printhead or the Printer hardware itself.
If you are in USA, please call 1-800-474-6836
Posted on May 11, 2014
3 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: machine cannot read new ink cartridge, is frozen
Is the ink cart a third party? if so replace with orgnial manufacture cart
Posted on Apr 25, 2010
  • 85 Answers
SOURCE: Cartridge carrier contacts appear dirty.
did you try the copy function? just to be sure that the problem is in your machine, not on the sending side.
Posted on Sep 18, 2011
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
My Lexmark x8350 has suddenly come up with Cartridge Error, Error #1203. I've followed all the remove cartridge, power off, power on, reinstall steps, but no good. I think it's the colour...
Hi Alan I think it is the cartridge that is causing your issue but I cant promise that it is.I can tell you from many years experience it very rarely is an issue with the printer breaking it is 99% of the time inferior consumables causing printers to fail, and sometimes wrecking printers so even when the customer does use good consumables it is too late and the damage is done, but we can't be sure of anything unless we start with basics and get 100% brand new Original Equipment Manufacturers carts (OEM) and stick them in. (no I don't work for Lexmark;)
Oct 31, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My printer keeps telling me "print cartridge
Maybe the contacts where the cartridge sits are dirty. What you can do is remove both cartridges and turn the printer off, pulling the power cable out so that the cartridge holder remain in the change position and you can see it. Then clean the gold contacts with a piece of cotton fabric soaked with medical alcohol. Left the printer turned off for 10-15 minutes so that the contacts become dry. Then turn it on and reinstall the cartridges. This might help.
Sep 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
When i try to print on my Lexmark 2300 it keeps saying scanner unit is open, but it isn't. I've turned it off and on opened and closed the unit but this hasn't helped
It could be the cartridges in the carrier. Please follow the steps below to identify and fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
5. Unplug and re-plug the printer into the power outlet to reset it.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You may also try to insert a different known working cartridge to determine if the cartridge you are currently using is faulty.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark Z2300 InkJet Printer
Error light keeps blinking and i changed all the toners
Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
Jan 30, 2010 | Dell 1320c Laser Printer
Cartridge
you may want to do a clean and calibrate on that unit
then do a test page
Apr 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP 564 XL Series Ink Cartridge Set for B8500 C309 D5400 -5 Pack Logo
Seeker5211
Seeker5211
