Question about D-Link DSM-312 MovieNite Plus
Dsm-312 no video in hdmi output
My dlink dsm 312 media center has no hdmi video output, I could only see it for the analog output, already did everything to try to fix it, until update the firmware to the latest version, change the HDMI cable, switch the TV input port but nothing, please if you can help ...
gunja
  • 43 Answers
SOURCE: Dlink Di-514 slow
hi,
Need to change teh MTU settings in your router.once you  will change it,, it will work
Posted on Oct 23, 2007
patemi
  • 366 Answers
SOURCE: Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Posted on Jan 26, 2009
nyilasrobert
  • 627 Answers
SOURCE: how to connect two 8 port dlink switch?
You have to interconnect the switches with the cable. Connect the computers to the switches. Also connect the internet cable in the switch too.
Posted on Aug 27, 2009
  • 15 Answers
SOURCE: cannot get ip through D-Link DGS-1008D Green switch
Your question is a little odd, as you should not be dealing with ip addresses when referring to a switch. Is the devices only function as a switch? Is it powered on? Are the ports enabled? Please clarify what you are trying to do when you "don't get ip addresses through"
Posted on Oct 27, 2009
  • 4 Answers
SOURCE: DLINK - DCS-900w Firmware Update needs install software?
Go to dlink.com. Select IP cameras. At the top is a search using Product Quick Find. Find the 900w and click on it.Select Support Resources. All the firmware and software is there.
Posted on Jan 30, 2010
We have a Denon AVR 4306 Surround Sound Receiver connected to a Motorola HDMI dual tuner DCT 6416 PVR. We're using component video cables to relay the video signal and RCA cables for the audio signal. We...
Try checking first the connection for the audio, then make sure the surround sound receviver is also connected properly and also turn everything OFF then turn back ON since you have a disruption just to refersh all devices and check it again if there will be sound already..
Hope that helps..........
Jun 22, 2008 | Televison & Video
Ps3 slimline
In the "System Settings" you are able to alter the Video Output setting from Analog to HDMI etc
This is important when running the output through to a HDMI TV.
Check that you have the correct setting for Video output for the relevant TV you are using.
Jan 04, 2014 | Sony Video Game Consoles & Games
Connecting a DLink DSM-310 streamer. Says it can't find our network. We have HDMI and are WiFi, but so far no luck. Connections have been checked and double checked.
is your wifi the older "g" and the dlink the newer "n" some wifi routers broadcast both other just one or the other. I assume that other devices see and connect just fine? It may need a "n" router to get the hd stream you need.
Oct 13, 2013 | Computers & Internet
I have connected my PC to Panasonic TH-L24C20D, I want audio output via TV speakers. what to do?
If your computer has an HDMI output, the audio is already connected to the TV in digital format via its' HDMI input. However, if you are using the VGA from the computer, you will need a separate audio system to output the audio from your computer. The VGA is an analog video only. Your TV does not have an audio input so therefore you need a speaker system from the computer.
Dec 20, 2010 | Panasonic Televison & Video
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Acer AX1700-U3700A with variable Audio on HDMI
Your problem isnt in your PC, it's because you chose the onboard sound to listen to music etc, which is normal. Unfortunately, you need to choose the HDMI Audio output if you want sound on your TV FROM the HDMI cable. Right click the sound icon located to the lower right side of your screen and choose (adjust audio properties). Now go to the audio tab and click the output device window and choose your HDMI audio output, whatever it may be called. Just pick the one that wasn't selected when you opened it and click ok or apply. Now all audio output is controlled by your Video card lol. Crazy aint it?
Feb 14, 2010 | Acer Aspire AX1700-U3793A PC Desktop
I just got a new PS3 from Sony (cause the old one was shot). The picture almost seems like ''fish-eye'' view. The game play and words during the game are all centered in the middle when they should be...
in the system settings check to make sure you are "set-up" to use the correct output, Composite, HDMI, also, try using the analog, output that normally comes with PS3 (analog adapter for PS2 will work also), but you have to change the output to analog to try, and you will have to change the settings back to composite or HDMI for 1080i while still using the analog, if you try it, then restart the PS3 and seee if there are any changes, try with as many different outputs, as possible to eliminate that before sending back to SONY for repair or replacement.
Thanks for the nice rating if this helps or solves your issue, or points you in the right direction, Fixya is appreciated. Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
DSM-320RD reset problem???
Your problem is most likely an incorrect video out setting. Examine how you are physically connected to your
TV, set your TV to view that input. After your unit is powered up and the Welcome dissappears, hit the Video Out button on your remote until you see the display.
Apr 24, 2008 | D-Link DSM-320RD DVD Player
D-Link DSM-312 MovieNite Plus Logo
Top D-Link Televison & Video Experts
David Payne
David Payne
Are you a D-Link Televison and Video Expert? Answer questions, earn points and help others
