Question about Elna Heirloom Edition 6005
My Elna 6005 turns on, but the mode buttons don't work at all. What can I do to fix it?
The machine will turn on and sew a straight stitch just fine, The screen works and shows the standard setting, but I can't change the setting at all.
  • jessica_lc86
    jessica_lc86 Jan 10, 2013
    I can't switch stitch modes at all. None of the buttons work. For example, if i press mode it does nothing at all. Ive unplugged the machine and turned it back on, ive turned it on while pressing enter. Nothing. Its weird because the screen works and shows everything just fine, i can sew with the standard straight stitch and I can wind the bobbin.
  • 3 Answers
Check the "Twin Needle Button" It will interfere with decorative stitches.
Posted on Mar 26, 2014
3 Suggested Answers
  • 136 Answers
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
  • 1116 Answers
SOURCE: My Elna 6005 Heirloom
When you switch sewing modes, what does the display read as far as the stitch type you are using?
Posted on Aug 19, 2011
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
Tip
Heirloom 6005 won't do decorative stitches or zig.....
I found out the hard way. If your machine just refuses to do any zig zag or decorative stitches..check the Twin Needle Key. I replaced the mother board at a cost of $400 and then found out that was the problem.
on Mar 26, 2014 | Elna Heirloom Edition 6005
Where do I get new feed dogs for the heirloom 6005? The current one does not pick up the fabric right, and I have to push it in with a seam ripper.
Are you sure the feed dogs are faulty, its more likely that they are full of fluff or need resetting if they are moving too low. Is your needle plate correctly installed too, if it is sitting up a bit high it will mean the feed dogs arent coming through the holes at the correct height.
I did buy a machine like this recently, owner said it did'nt sew. The needle plate was fitted upside down, 30 second fix!
If you don't have a repairer you know of in your area, then start with the Elna website www.elna.com, go to your country, then "Dealers" and locate your local Elna dealer.
Jul 10, 2011 | Elna Heirloom Edition 6005
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
Elna Envision 8007 feed dogs dropped and can't get get them to go back up ...the switch doesn't make a difference. Had this problem before and thought it was fixed. This is the first time I needed to...
Have you actually starting stitching a seam after sliding the feed dog control back to normal position?
In most cases, the feed dogs don't magically pop up until the machine has moved through a stitch sequence.
Put a piece of fabric under the pressure foot, lower the pressure foot, then turn the flywheel towards you two or three turns or use the needle up, needle down control button to make a couple of stitches - this should get them back.
Apr 15, 2011 | Elna 8007
Loose tension on bobbin thread
Using a scrap piece of material; try tightening the upper tension a bit at a time until the bobbin thread is smooth. Test stitch after each setting until you get the desired effect...happy stitching Gal.
Apr 11, 2010 | Elna Heirloom Edition 6005
Machine Elna Supermatic 722010 When I sew with a single cam all works properly the problem comes with any twin cam, the upper cam follower has a spring holding it away from the cam, how do I get the upper...
tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Mar 29, 2010 | Elna Heirloom Edition 6005
Zig zag won't work
Make sure stitch width slider is not set to zero. If not then you either have a bind in the needle bar pivot or an electrical problem (bad stepper motor or bad circuit board).
I can't remember if this machine has a twin needle lock out, if so turn it off.
Good Luck!
Jan 28, 2009 | Elna 2007 Mechanical Sewing Machine
Satin stich scallops
stitch no. 29 "F "foot 7.0 width 0.4 length tension 2-3
Jan 28, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
105 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
