Question about Dishwashers
Frigidaire fdb1050rec2 dishwasher gets no water
Ive already replaced the electrical panel inside the front door where the knob goes into and I replaced the main wiring harness because there were 2 burnt red wires where the electrical panel and the main wiring harness connect together. Ive also replaced the water intake valve because it was still getting no water. It still gets no water. The water inlet hose is getting water to the dishwasher. The overflow switch is not stuck, it moves freely. What is keeping this dishwasher from taking in water ?
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
aborcass
  • 2651 Answers
SOURCE: door panels for frigidaire dishwashers
sure its possible,stainless steel door 154538305 approx $100
Posted on Feb 23, 2008
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Posted on Apr 06, 2009
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
Dishwasher
I need to know who made the dishwasher.  Was it GE, Hair, Kenmore....? Pllease do not vote yet, just post a comment.
Oct 25, 2007 | Dishwashers
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
How do I get my ge dishwasher to run? the lights
Hello there and welcome to fixya
If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. Make sure to turn off the power to the dishwasher before attempting any repairs
To solve a door switch problem, you may be able to adjust the door latch's strike slightly, using a screwdriver
then make sure the door closes securly, if this doesent work
please check the timer as follows
Dishwasher timer concerns can be classified into two general categories: the timer cannot be advanced manually and appears to be stuck or intermittent automatic timer advancement.
1. The timer dial cannot be advanced manually and appears to be stuck. Stuck timers are generally caused by objects that prevent the detergent cup from opening, or by a sticky substance between the timer dial and the control panel.
  • Objects that prevent the detergent cup from opening: If your timer will not advance, open the dishwasher door and check for items that may be blocking the detergent cup.
    Also, check the detergent cup:
    • It should be fully closed at the start of a cycle.
    • It should be fully open at the end of the cycle.
    • Almost fully open between main wash and final rinse.
    If it is in any other position, try to open or close the cup while at the same time rotating the timer. This should free it up. To prevent a reoccurrence, make sure nothing blocks operation of the detergent cup when the dishwasher door is closed and operating.
  • Sticky substances like orange juice that get between the timer knob and the front of the control panel on some models will bond the timer knob to the control panel. If you have this condition, it will be virtually impossible to rotate the timer knob while gently pressing the knob in toward the dishwasher. It will rotate normally if the knob is gently pulled away from the dishwasher while rotating the knob.
    This problem can be solved by gently pulling the knob away from the control panel and cleaning behind the knob with a damp cloth. Do not use excessive force because the knob is attached to the control panel on models affected by this problem. If this operation cannot be performed, service should be contacted to repair the problem.
2. Intermittent automatic timer advancement. This can be described as the timer can be advanced manually, but it does not advance automatically in spots for up to 30 minutes.
  • This is almost always a normal condition and always occurs on models with a "Delay Start" feature.
    Delay start timers increment or advance a couple of degrees once every minute or so during most of the cycle. However, during certain parts of the cycle they increment once every 30 minutes. This gives the dishwasher time to do the job of cleaning your dishes. The long increment times occur during "Delay Start", "Hot Start", "Normal Wash" and "Dry" cycles.
    The timer will not move at all during these delay periods. This is normal operation and service is not needed. If you notice delay times substantially longer than 30 minutes, replace the timer
  • Also ensue that you are getting adequate water pressure and the unit is getting water inside and that the water is at the right temperature 140 is the min. for most units
  • Please check the above and let me know what you have found so i can continue to help there is a lot of things to check but these that i have provided are the most common thing that need to be checked first ok?
  • Best regards Mike
Aug 21, 2011 | GE Dishwashers
The top spray arm is not turning as best i can tell. bottom one is.. frigidaire model # fdb1050rec2. please help! thank you
If your dishwasher does not fill up with the correct amount of water the top spray arm will not get the water pressure it should.
The water level should be just under the heating element.
Aug 03, 2011 | Frigidaire 24 in. FDB1050RE Built-in...
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
FDB1050REC2
Follow up to my Jun 02, 2008 post. We had a service tech come out today, and it turned out that the door switch was bad. The neutral side had continuity with the door shut, but the hot side was sporadic. A new switch has been ordered.
According to the Frigidaire tech sheet attached to the door, which is located beneath the control panel and behind the door skin, the problem could potentially be a bad control panel also.
Hope this helps someone in the future!
Nov 11, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
