Question about Sony CDX-M800 CD Player
Black out i pushed turned the blackout button on to see what it would do and now none of my buttons work when i press them, my screen is blank and my cd's still play but i have to hit the reset button to take them out and i can't change the volume or song.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Press and hold OFF to reappear display.
    OR set Off blackout. Page-17 user manual of CDX-M800
    Sergeant:
  • 233 Answers
This is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Posted on Jan 21, 2009
My LG R410 makes wierd whenever i press any buton noises and blank screen
It will do that if the screen is black, Beep repeatedly, every time you tap a button. If that is the only problem you have, you don't have a problem. Just don't push the keys a blank screen. The statement "it was fine then i shooted it down then again i turn it on it was blank" , could you rephrase that statement? Is the machine not booting?
Nov 12, 2012 | Computers & Internet
My mini NB300 notebook has blank (blackout) screen when it is "on"
I had the same problem with Mini NB300. Computer would start to boot and the screen would go black. I tried everything humanly possible and stumbled onto the solution to resolve it.
1. Plug the AC Adapter into the Notebook PC.
2. Press and hold the Power button for 5 Seconds to turn off the PC.
3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
I hope this will work for you.
Jul 12, 2011 | Toshiba Computers & Internet
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
Um do u know were the dsi reset boton is?
The Nintendo DSi and DS are having none reset buttons, use the power switch or restore the factory setting from the setting menu, read the manual also first.
Succes.
Aug 30, 2009 | Nintendo DSi Black Console
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Screen black out
best way to trouble shoot a monitor is to plug into a different monitor do you have a desktop monitor you can try?also alot of laptops have a small button that turns monitor off when you shut it down around the base of the monitor make sure it isnt stuck.is it going into hibernation? try pulling the battery and unplugging it then plugging it back in.if it is stuck in hibernation that should work.
Apr 23, 2009 | HP Pavilion DV6500Z Notebook
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Camera turns on but screen is blank and no buttons work
h...i try to do the following steps...
Turn off the camera.
Ensure the camera is not connected to an AC power adapter.
Remove the battery from the camera for 15 seconds.
Reinsert the battery.
Turn on the camera.
thank u rate me!!
Feb 10, 2009 | Fuji Finepix® F31fd Digital Camera
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Sony CDX-M800 CD Player Logo
384 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
