Question about Xerox Office Equipment & Supplies
Xerox DC252 fault 127-311
Intermittent fault code 127-311 happens after job is done. Turning the machine off/on can get another job off before the fault reoccurs. Just started today. What specifically does the code mean (what part needs to be replaced)? What is the RAP for this code?
checkitright
  • 1362 Answers
SOURCE: xerox U2-2 erroe code
You did not say what type of copier this is, but most codes are the same for most of the copiers.
Look at this link:
http://www.copier-help.com/copier-help/ecs/xerox/ecx1012.html
Posted on Oct 26, 2007
SOURCE: xerox 5334 fault code U4-1
Reset the fault code first as follow:
Enter in diagnostic mode
Enter 20-3 and press 0 then press start again .
Hope it will solve if not done check the heater lamp continuty if found fault replace same.
Posted on Sep 20, 2008
  • 990 Answers
SOURCE: Xerox WC Pro 423 fault code U4-6 & U4-4
Hello sir; The U-4 code all are fuser problem, there haave noway to fix it the only way is replace the fuser unit
Posted on Aug 23, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
  • 2072 Answers
SOURCE: fault code 006-381 on a xerox workecentre 24
That is a ROS ( laser ) fault.Either the ROS unit or the MCU ( main processor board) have failed.
Honestly, its a tossup as to which is the problem.
Posted on Mar 31, 2010
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
How to fix fault 116-365 of wc 5330
Solutions for : Fault Code 116-365: An Internal Shutdown Occurred After an SPL Processing Error Related Fault Code: 116-365 Solutions ranked by relevance:
  1. Delete All Jobs From the Job Queue
  2. WorkCentre 5325/5330/5335: Power the Printer Off and On
May 27, 2014 | Xerox Office Equipment & Supplies
U 60
U60: Job Offset Home Position error. Job Offset does not reach home position.
  1. Cycle the printer's power.
  2. If the problem persists follow the procedure below.
Check the following for evidence of fault or damage: Home Position Sensor Adjuster. Home Position Sensor. SNS Harness: is there any damage or misalignment? The rest of my steps can only be done in Technician's Service Mode and should only be done if you are qualified to service this machine.
Mar 29, 2014 | Xerox Phaser 7400/N Printer
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox phaser 8200 fault code 15.004.45:30386
That is a drum heater fault code. The drum heaters are 2 ,,, 150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps. Let me know if you want me to send you info how to change them.
rak458@aol.com
Mar 09, 2010 | Xerox Phaser 8200 Laser Printer
Fault has occured error code 103-208
First off. look around carefully and be certain everything is plugged in properly. Sometimes that code is caused my mis communication between the document feeder and machine, scanner and machine,finisher and machine, etc. I would follow all the connectors back and disconnect, then reconnect them.
If that doesn't resolve the problem, then remove the back cover and reseat all the connectors you can see on circuit boards.
With moving the machine, I am pretty sure you have a connector problem. But the 116 and 103 codes are related to software and mostly due to mis communications between the device peripherals.
Also on a hunch, just try to remove the RJ 45 network connector and turn the machine on. If there happens to be some odd job, something like an internet print job on that line, it will shut the machine off with that 116 code you reported.
Let me know and we will go from there.
Jun 02, 2009 | Xerox WorkCentre M-24 Color Copier
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
444 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
